Water Pump
Sean (TX)
01-18-2008 12:22:46
I developed a screetching noise up front yesterday. Not the belt. Sprayed some wd-40 on it and no change...Kinda fades in and out at time's. Water pumps make weird noises when the go??...It was getting dark last night and didnt look to close. Pretty crappy weather today. Might look at it saturday afternoon..
Hobo,NC
01-19-2008 04:53:09
 Re: Water Pump in reply to Sean (TX), 01-18-2008 12:22:46
Remove the belt and see iffin the noise is still their,,, spin and feel test,,,, tip to clean a belt throw some bake"n soda on it start tractor,,, repeat a few times,,, never put belt dressing on a automotive V belt,,, NEVER
Sean (TX)
01-18-2008 16:00:51
 Re: Water Pump in reply to dahermit, 01-18-2008 12:22:46
I put a few drops of oil in there once in a while...Front one I think may be pre lubed?
jon
01-18-2008 15:53:31
 Re: Water Pump in reply to Dan in CO, 01-18-2008 12:22:46
Ross Pugh(NC) said: (quoted from post at 19:49:23 01/18/08) Yep, jon, I bought me one a couple of years ago and it is absolutely amazing how well you can hear things with one. Now I know why doctors use 'em. They are good.
We bought a regular one before my girl was born. Pretty wierd listening to all that going on in there!
jon
01-18-2008 15:52:06
 Re: Water Pump in reply to locodriver, 01-18-2008 12:22:46
Bob said: (quoted from post at 19:40:55 01/18/08) Yeah, and BE CAREFUL not to have the fan blade ZZZZINNNGGG the probe while you have the earpieces in place.
(You DON'T want to know wahy I know this!)
Or don't bump it into a metal building either! Ouch!! :oops:
Sean (TX)
01-18-2008 15:49:06
 Re: Water Pump in reply to dan in co, 01-18-2008 12:22:46
No wobble in the fan. The fan and genny both spin pretty freely with the belt loose....If it aint one thing it is another!! :( Water pump at TSC 60 bucks...My give it a good flush then replace the pump...Slowly but surely replacing one part at a time on the old N...
jon
01-18-2008 15:32:17
Getcha one of these bad-bays. They're even on sale at Harbor Freight for $1.99. Pretty handy sometimes.
[img]third party image[/img]
Ross Pugh(NC)
01-18-2008 15:49:23
 Re: Water Pump in reply to jon, 01-18-2008 15:32:17
Bob
01-18-2008 15:40:55
vacman
01-18-2008 14:45:21
Sean
That is exactly the noise I was hearing from my 47 2N. I poted a while back regarding (HOT GENERATOR) Feel your genny and I will bet it is very hot. By the way My problem was a bad cutout and the new one had a problem as well, but it was not hooked up bacwards. You guys sugested I use a bridge rectifier and mount it in the cutout case.This has worked very well and have had no problems since. Thanks for the tip. By the way it is going down to -30 windchill this weekend BRRRRR but i bet my N will start
Bob in Wisconsin
Mike OH
01-18-2008 14:37:49
Don't know if I would have sprayed WD-40 on the belt..... . may cause it to slip some if the bearing in the generator / alternator or water pump is going. The old screw driver trick up to the ear while running may help you pin point the location of the noise. Just don't get your head down too close to any moving parts while listening or you may develop some new kind of sounds you haven't heard before. LOL
Sean (TX)
01-18-2008 14:15:34
 Re: Water Pump in reply to Dean, 01-18-2008 12:22:46
Could be the genny don B...Have not pin pointed it....Water pump have a weep hole? Dont see any leaks....
lonestarjeff
01-18-2008 15:55:29
 Re: Water Pump in reply to Sean (TX), 01-18-2008 14:15:34
Sean...have you ever rebuilt your genny or lubed the little bushing in the back cover? After reading your post I don't recall ever adding a drop of oil thru the little hatch on the back cover of my genny.
Jeff
don b
01-18-2008 13:37:57
Sean.....if you think that noise is bad...just wait till the fan goes thru the radiator. lol don b
Sean (TX)
01-18-2008 13:12:06
 Re: Water Pump in reply to jon, 01-18-2008 12:22:46
Decide to brave the elements...only 32° right now and a bit of drizzle...Not doing when I started it up.
After it started to warm up started doing it on and off...Annoying noise and hard to pin point...
old
01-18-2008 15:14:33
 Re: Water Pump in reply to Sean (TX), 01-18-2008 13:12:06
Reach in and see if the fan will wobble a little bit if it does then you have found your problem. Another way to see is fire it up and run it till it makes the noise and then loosen the fan belt and turn the generator and fan by hand and see which one makes the noise.
Sean (TX)
01-18-2008 12:36:03
 Re: Water Pump in reply to Dan, 01-18-2008 12:22:46
Never overheated...
Jim SC
01-18-2008 12:33:43
Last spring, my 4830 Ford diesel) water pump started squealing LOUDLY while I was spraying corn. It stopped after a while and I watched the temp. gage and it didn't overheat so I finished spraying and then tore it down. It was locked up with vanes broke off. (It didn't overheat as there was enough natural circulation and no load on the tractor) I expect a N water pump would make the same noise, but it will overheat, even at idle.
