Help putting woodruff key in spindle
rd99
01-22-2008 09:47:41
Before I whang the woodruff key into the spindle I wanted to ask some help.
I've got the 5/16" x 1-1/4" woodruff key. I checked the key in the steering arm and it fits perfectly in that slot, but fitting it into the spindle arm looks to be a tight fit.
Should the woodruff key fit easily into the slot or does it require some light taps with a hammer? Should I coat the key with something? Should I do something else?
By just using my hand to place the key in this is as far as it goes:
third party image
The slot without the key in it looks like this from a slightly off center view (it's still got a bit of oily crud in there I'll clean out):
third party image
rd99
01-23-2008 12:02:37
 Re: Help putting woodruff key in spindle in reply to rd99, 01-22-2008 09:47:41
Thanks for the info guys, I just tapped it in with a small hammer after cleaning out the slot.
gahorN
01-23-2008 09:47:07
 Re: Help putting woodruff key in spindle in reply to Britcheflee, 01-22-2008 09:47:41
Clean the slot with stiff brush/solvent, and use a C-clamp to press it in.
Blackhole49
01-23-2008 11:35:49
 Re: Help putting woodruff key in spindle in reply to gahorN, 01-23-2008 09:47:07
I just did mine last weekend. Tapped lightly with a small hammer. No problems.
Hobo,NC
01-22-2008 19:16:10
slite interference fit,,, made that way,,, spose to b that way,,, debur the slot and knock it in.
Dunk
01-22-2008 10:10:53
I would clean that out really good with a small screwdriver, or pocket knife blade, or whatever, and just tap it in.
