1940 to 1943 dash conversion??
Ron Tracy
01-23-2008 06:12:55
Is it possible to convert a 1940 Cast aluminum dash set up to the newer steel?? By changing upper components??
Sean (TX)
01-25-2008 17:03:35
 Re: 1940 to 1943 dash conversion?? in reply to ZANE, 01-23-2008 06:12:55
John Smith has a aluminium one for sale!!
190 bucks plus shipping...
third party image
Sean (TX)
01-23-2008 11:31:52
 Re: 1940 to 1943 dash conversion?? in reply to Ken Crisman, 01-23-2008 06:12:55
Ron Tracy said: (quoted from post at 13:14:36 01/23/08) Yes the starter button is in front of the shifter.
Ron
So is the starter button on my 41...You could go with a cast iron one too...Thats what I have on my 41. Just replace the tranny top cover along with the shifter and everything above it.
KCM
01-23-2008 08:49:56
 Re: 1940 to 1943 dash conversion?? in reply to Ron Tracy, 01-23-2008 06:12:55
Does your 1940 have the starter button next to the shifter? Then I'm sure you could change the upper steering housing out without a problem. I know of someone who did. If it doesn't have the button, then you will need to change the transmission cover too. Your tool box will either need to be updated too or remounted as the aluminum dashed tractors took a different one than the steel dashed.
Ron Tracy
01-23-2008 10:14:36
 Re: 1940 to 1943 dash conversion?? in reply to KCM, 01-23-2008 08:49:56
Ron
Mark Pearce
01-23-2008 11:28:44
 Re: 1940 to 1943 dash conversion?? in reply to Ron Tracy, 01-23-2008 10:14:36
Ron, Did you just buy one off ebay this morning? I was watchin a dash and a hood from the same guy. I bought his hood for like fifty bucks. Didn't need the dash but I should have bid on his dog legs.
Mark...
