Starter problem... NEED HELP
quiggs12
01-23-2008 14:41:15
My starter broke so I took it off to have it rebuilt. However, the large spring and one of the washers that holds the spring on were not on the drive. I don't want to put the rebuilt starter on if those parts are in the tractor. How can I get these out without breaking apart the tractor??? Can I drain the transmission and go though the drain plug??? Any help would be nice. Thanks
soundguy
01-24-2008 06:37:42
 Re: Starter problem... NEED HELP in reply to quiggs12, 01-23-2008 14:41:15
Yes.. you -could- drain the tranny and go in thru the drain plug.. but all you would get is dirty ahnds after a couple frustrating hours cuz the transmission cavity and the clutch bellhousing cavity are SEPERATE.
If it really bothers you, get a coathanger and magnet and fish around in there till you find something.
You might want to invest in a set of manuals for your machine as well.. A quick look at an exploded parts diagram will show the 2 cavities in question...
soundguy
Bruce (VA)
01-23-2008 18:11:29
There is plenty of room in the bell housing for it; I'd just let it be. Short of fishing it out, the only other way to get to it is to split the tractor.
Duner Wi
01-23-2008 14:57:46
Duner Wi
Might not bother a thing but if it were mine I would go thru the starter hole with an earth magnet on that telescopes and try to fish it out. Might work but have never done it. Those magnets will pick up a claw hammer so should be strong enough to pull the spring out if you can locate it. I know some people have left them with out problems .
quiggs12
01-23-2008 15:02:11
 Re: Starter problem... NEED HELP in reply to Duner Wi, 01-23-2008 14:57:46
tried but couldn't tell if it was in there...
Sean (TX)
01-23-2008 14:46:59
 Re: Starter problem... NEED HELP in reply to JMOR, 01-23-2008 14:41:15
Found mine in the void under the flywheel...
third party image
quiggs12
01-23-2008 17:43:55
 Re: Starter problem... NEED HELP in reply to Sean (TX), 01-23-2008 14:46:59
Why is there a cotter-pin in the bottom of these??? I have one on mine and it looks to be there in your picture.
Bruce (VA)
01-23-2008 18:09:32
 Re: Starter problem... NEED HELP in reply to quiggs12, 01-23-2008 17:43:55
It keeps the drain hole open so excess tranny/engine oil will drip out & stay off of the clutch.
Sean (TX)
01-23-2008 14:44:24
 Re: Starter problem... NEED HELP in reply to winehead, 01-23-2008 14:41:15
Dont worry about them. Plenty of room for them in there. Found spare parts when I split mine awhile back..
quiggs12
01-23-2008 14:45:01
Probably should have mentioned it is a 1946 2N. Thanks
