Ford 2N Drawbar Stabilizer Brackets???
Pappy
01-25-2008 12:16:21
Have a 2N Ford with a drawbar installed. I want to put a ball hitch on the drawbar to pull a trailer. There is a bracket that can be installed on the drawbar and lift arms to keep the drawbar from rotating. What are these called and does anyone know where to get them??
I saw some for a class 3 hitch, but they are much too big. Thanks!
D Squared
01-26-2008 05:09:59
 Re: Ford 2N Drawbar Stabilizer Brackets??? in reply to Pappy, 01-25-2008 12:16:21
Here is something I drew up on a napkin when I had access to a free machine shop. (I'm retired now)
third party image
Sean (TX)
01-26-2008 04:45:10
 Re: Ford 2N Drawbar Stabilizer Brackets??? in reply to soundguy, 01-25-2008 12:16:21
Tractor supply carries draw bar locks to...
third party image
Pappy
01-25-2008 12:55:00
Thanks for all the good ideas. I learned a lot. I like some of the inovations you showed. We should be up and running in no time.
Carl K
01-25-2008 12:38:21
Just 8n's has a drawbar lock listed for 19.00 DBL-2 under Hydraulic Lift & related Parts. (Keeps 11 hole drawbar from turning).
Too Tall
01-25-2008 12:26:14
There are drawbar locks as mentioned above, as well as some other ideas folks have dreamed up that are all a bit different. Some are better at specific tasks than others.
See this link for a similar discussion:
Link
This is similar to what I use:
third party image
I think SouNdguy made this one:
third party image
There are other contraptions too, so take a look at what is out there...
I'm sure others will post after me with other ideas.
TooTall
JMOR
01-25-2008 12:21:44
 Re: Ford 2N Drawbar Stabilizer Brackets??? in reply to Jack - Illinois, 01-25-2008 12:16:21
Pappy said: (quoted from post at 16:16:21 01/25/08) Have a 2N Ford with a drawbar installed. I want to put a ball hitch on the drawbar to pull a trailer. There is a bracket that can be installed on the drawbar and lift arms to keep the drawbar from rotating. What are these called and does anyone know where to get them??
This is probably just one of many.Link
KCM
01-25-2008 12:20:43
I think you are talking about the drawbar lock. See the link below for one source for this part.
KCM
01-25-2008 12:21:33
 Re: Ford 2N Drawbar Stabilizer Brackets??? in reply to KCM, 01-25-2008 12:20:43
Here is another option that will allow you to add a ball.
KCM
01-25-2008 12:25:35
 Re: Ford 2N Drawbar Stabilizer Brackets??? in reply to KCM, 01-25-2008 12:21:33
Here's a style from this web site.
36 coupe
01-26-2008 04:33:37
 Re: Ford 2N Drawbar Stabilizer Brackets??? in reply to KCM, 01-25-2008 12:26:33
A short piece of square tubing that will fit over the drawbar and two lengths flat stock will make a draw bar lock.If you dont have square tubing it only takes a few minutes to weld up some angle steel.
