Order Ford 8N Parts Online
8N front wheel slop normal ??
osweld
01-25-2008 19:54:58
looking at an 8N and when you grab the front tire at 12:00 you can push and pull it a little is this normal ? If not what is the fix ?? Also should you be able to do this to the rears ?? Again if so what is the fix ?? Thanks
Dell (WA)
01-25-2008 20:06:56
 Re: 8N front wheel slop normal ?? in reply to osweld, 01-25-2008 19:54:58
Oswald..... ..NO SLOP..... .frontwheel slop as described is usually loose bearing nut inside hubcap. Altho it could also be BAD bearing. Only way to tell is to clean and re-greese. Simple, eh?
8N Rear ag-bar tire slop means the tapered spline rearaxle hub has worn and the 450ft/lb BIG NUT is loose. New hub $50, (cheap) This has been asked and answered many times, you might want to check the archives at the top of this great N-Board. As a general rule, worn hub splines aren't a "safety" issue but keeping the BIG NUT ON is..... ...Dell
osweld
01-25-2008 20:17:25
 Re: 8N front wheel slop normal ?? in reply to Dell (WA), 01-25-2008 20:06:56
thanks. On the front is there an inner and outer bearing like on a car ?? Or just a tapered bearing ?
So I could just pull the nut and repack nd tighten or preload the bearing nut ? Is ther instructions here how to do it ? If the rears just had a little slop and the nut was tight would you leaveit alone ? Is there instructions here to chg hubs too ?
Thank you
HCooke
01-26-2008 05:54:50
 Re: 8N front wheel slop normal ?? in reply to osweld, 01-25-2008 20:17:25
Owner's manual and IT FO4 shop manual are available for sale on this site. Both are valuable if you are going to do much work on your tractor. Front wheels have inner and outer bearings and are easy to clean inspect and repack.
