2N transmission oil
quiggs12
01-27-2008 07:49:35
Do I get just a straight SAE 90 oil or is there something else that I can use??? I live in Maine so it does get cold and I know I am suppose to use 80 if it is below freezing. Thanks
Dan
01-27-2008 08:04:21
 Re: 2N transmission oil in reply to quiggs12, 01-27-2008 07:49:35
You can use the New Holland Spec 134-d hydraulic oil - it is the equivilent of 20w. Know though, that this lighter oil will find its way past old seals and gaskets much eaiser and will cause leaks and usually oily brakes.
Dan
Bob
01-27-2008 08:03:24
You can use UTF "Universal Tractor Fluid" for the cold weather. It will be more "leaky" in summer, and, if the lift hydraulics are at all weak, they will perform worse with the thinner oil.
