Does a Sherman take more oil than reg tranny
Osweld
01-29-2008 17:31:55
ok if you have a Sherman do you drain and refill the same as a regular tranny ? Same amt ? Drain plug same ?
9NJoe
01-29-2008 17:35:19
 Re: Does a Sherman take more oil than reg tranny in reply to Osweld, 01-29-2008 17:31:55
Oswalt,
Simple answer is yes same amount. The sherman is splash lubed from the main tranny. It has about a quart in it but you cant get it out without splitting the tractor so if you change the oil, the sherman oil will eventually get replaced with clean oil.
Joe
