Aligning rear axle shaft with differential gear
Am-Seb
01-30-2008 11:15:50
Brakes, brakes! Gimme a break! Can't find in Archives. When (hopefully) I get to installing the new axle, I can't find how it could be held in position to engage the differential gear--seems would be difficult trying to hold it from the outer end. Dawned on me that if put the hub on and just snugged up the outer nut, maybe with help I'd have the leverage to guide the shaft home, remove hub and get on with brake work. Is this how it's done, or what? Thanks again for all your help. Angelo
Steve IA
01-30-2008 12:01:33
 Re: Aligning rear axle shaft with differential gear in reply to Am-Seb, 01-30-2008 11:15:50
I had the same concern the 1st time I reinstalled an axle. The next ~50 something times I knew it was no big deal. Just grab the outside end and push and twist a litle and it will go right in. Good luck
Steve 8N 169302
Am-Seb
01-30-2008 20:56:53
 Re: Aligning rear axle shaft with differential gear in reply to Steve IA, 01-30-2008 12:01:33
Thanks, Steve IA, I'll do what you and Dunk say. Angelo
Dunk
01-30-2008 11:25:35
Assuming we are talking 8N, due to you saying the hub and the nut.
It seems that I was able to slide mine in, and then still had enough leverage to push down on the outside end, and raise up the inside end.
If I recall correctly.
I don't recall it being a problem.
Am-Seb
01-30-2008 11:32:18
 Re: Aligning rear axle shaft with differential gear in reply to Dunk, 01-30-2008 11:25:35
Thanks, Dunk. I forgot to mention '48 8N. Angelo
