front axle
8n-charley
01-30-2008 13:31:08
Need some advice on the front axle, do the below look ok to use with the uneven wear on the top, or what could be done to them so to use? They fell apart when I took the top arm off, bearings etc are toast. Would a rebuild kit take care of it?Any help appreciated, I am stuck on what all to do. thanks for the help as always, you guys are great.
third party image
third party image
third party image
DON TX
01-30-2008 20:27:46
 Re: front axle in reply to 8n-charley, 01-30-2008 13:31:08
I'd replace the bushings and the bearings. I did mine a couple of years ago and don't remember any problems. Just a dirty job. Relatively cheap. Just don't let mission creep set in. I would check the kingpin bushing while I was that close. HTH
DON TX
8n-charley
01-31-2008 04:01:35
 Re: front axle in reply to DON TX, 01-30-2008 20:27:46
Thanks Don, I really didn't know what to do , new axles are expensive, would putting a brass washer on top under the arm help to control or even out the wear?
DON TX
01-31-2008 15:26:21
 Re: front axle in reply to 8n-charley, 01-31-2008 04:01:35
I'm not sure exactly where your talking about. The 2nd pic shows a bushing sticking up. That should be set lower when they are replaced. My MPC shows the axle rides on the spindle bearing. There is a dust seal at the top of the spindle. HTH
DON TX
