Order Ford 8N Parts Online
8N Carb leaking
Eriklane
01-31-2008 04:43:03
It's been cold in MI, and my 8N has issues starting. Gas drizzling out of the carb. Finally it got started, after a jump, and then it was fine. Did this twice. Took the carb off, the float seemed fine, clean, floating free. I took the needle valve out, seemed fine.
Any ideas?
JMOR
02-01-2008 20:05:00
 Re: 8N Carb leaking in reply to soundguy, 01-31-2008 04:43:03
kenmcg said: (quoted from post at 23:21:01 01/31/08) This is just a Ken thing. My 8N starts easy and stays running in any kind of temperature. Every time you shut it off, close off the fuel knob on the sediment bowl and let it run 2 more minutes until it dies. I have been told that they will ALL leak fuel if you leave the fuel petcock on the sediment bowl open.
I won't argue one bit that it is a good idea to turn off the gas when not in use, BUT to say that they ALL leak is just wrong. I have the exception, I guess, because it can be left on for months without a problem. I try to remember to turn it off, but I haven't always. Sooner or later that little piece of trash will get me when I forget, but they do not ALL leak. This one is brass on brass, no soft tip needle here.
redleg
02-01-2008 13:53:08
 Re: 8N Carb leaking in reply to Eriklane, 01-31-2008 04:43:03
Oh, and how do you like the weather today? I work in Rockford. Should be burning the carbon off the valves with all this snow to plow.
redleg
02-01-2008 13:49:31
Erik, I just got mine this winter too. Carb was wet and started hard so I picked up a carb kit at tractor supply. Starts good now with choke open in the cold and close the choke quickly. My tractor is in ruff shape too. If you get a kit from tractor supply, the $2?.00 kit labelled doesn't come with the lower butterfly gaskets. The $4?.00 kit I saw there was labelled for the 9n and 2n and looked like it came with everything. I should have compared them in the store.
Eriklane
02-01-2008 04:57:35
I always shut the gas off.
kenmcg
01-31-2008 19:21:01
Phil9N3667
01-31-2008 19:32:16
 Re: 8N Carb leaking in reply to kenmcg, 01-31-2008 19:21:01
You can leave it on while you use it off and on during the day, etc. but if you don"t cut it off when you"re done there"s always the chance of the needle not seating 100%. With the price of gasoline these days can you afford that? Also, if it floods and the wire mesh in the throat isn"t open you"ll end up with a crankcase full of gas! That gets expensive fast.
Bruce (VA)
01-31-2008 19:28:49
Yep, leaving the gas turned on is asking for trouble. This is from a post here last October:
"We just had an 8N in the shop that the owner wanted us to fix the carb leak and replace the starter because the engine wouldn"t turn over. Turns out the base had more gas in it than oil and the bearings didn"t get enough lube from the diluted oil and seized the engine. I think of that tractor every time I park my tractors now and don"t forget to shut the fuel off."
Check out tip # 9, below as well.
Eriklane
01-31-2008 09:22:52
 Re: Apply the choke for SHORT intervals... in reply to Eriklane, 01-31-2008 04:43:03
So you're saying that continuous choking will flood. Viola' That must be it...My first 8N...that explains it.
Thank you.
Eriklane
01-31-2008 06:42:29
Only after I have cranked it a few times, choked.
Bob
01-31-2008 08:40:31
 Apply the choke for SHORT intervals... in reply to Eriklane, 01-31-2008 06:42:29
Each operator and tractor need to get to know each other, 'cause some are more "quirky" than others. Basically, learn to get it cranking over, pull the choke out ALL THE WAY for a couple of seconds/revolutions, then shove it forward, repeat as needed. Once it fires up, the choke can be pulled out as much as needed to keep it running for the first few minutes. If you simply pull out the choke, and keep cranking it, in very little time, it will be "flooded" and gas will be dripping out of the sintered bronze air horn drain.
souNdguy
01-31-2008 05:43:05
As Bob points out.. if it was a hard start and you used lots of choke, then there is a drain built in to drain that excess gas off. if it doesn't leak just setting there.. you may be fine.
might want to do a general tune-up to try to get better cold start performance.
soundguy
Bob
01-31-2008 04:48:51
Does the carb leak (run over)while it's been siting, or AFTER you crank it with the choke on?
8nguy
02-04-2008 19:05:34
 Re: 8N Carb leaking in reply to Bob, 01-31-2008 04:48:51
I have way much gas flowing throuh my carb wy ?
8n guy
02-04-2008 19:21:19
 Re: 8N Carb leaking in reply to 8nguy, 02-04-2008 19:05:34
Also found gas and oil
8nguy
02-04-2008 19:24:59
 Re: 8N Carb leaking in reply to 8n guy, 02-04-2008 19:21:19
sorry! I found gas in the oil!!!
