air filter
Richard Kelley
02-01-2008 12:43:22
Looking for a retrofit ait filter / cleaner fot my 8n just does not have all its suction it use to have.
The oil bath is just has to much restriction.
Suggestions
yellekrt@gmail.com
PhilipIN
02-04-2008 04:20:19
 Re: air filter in reply to Richard Kelley, 02-01-2008 12:43:22
third party image
Richard, I sent you an e-mail with more information about this air cleaner. If you did not get it, send me a private e-mail. Philip.
Jason1(Pa.)
02-02-2008 16:14:13
You would be surprised to know a lot of times when you put one of those filters on you will loose power. I put one on a pulling tractor one time and it lost so much power it was amazing. Put the stock set up back on and it was normal power again. You have to do alot of modifications before you benifit from a paper filter like that. Plus the oil bath set up works so much better
Joe in MI
02-01-2008 13:18:40
Doesn't it make you wonder how long it had been since it was cleaned out? Another testement to how forgiving these machines are. Can you imagine if you restricted your car's intake that much?
Joe
Joe in MI
02-01-2008 12:56:04
I'm no expert, but I think for these tractors the oil bath air cleaner is the best (and only) way to go. There is a cyclone precleaner (I think this site sells them) to get the heavier particles out.
Have you taken your air cleaner apart and cleaned it really well? When I got my 51 8n, the top of the air cleaner (where the air enters) was so packed (like, chisel it out with a screwdriver packed) with dirt that the air only had a 3/4" hole to get through. The oil cup was filled with sludge, and and the steel mesh element was nearly clogged. I cleaned all that, and it ran like a different machine.
I'm not even aware of any other air cleaners available. I may be wrong though - I think I was wrong once before. :)
Just my 2 cents, and what worked for me
Joe A
tiny-t
02-01-2008 13:04:22
 Re: air filter in reply to Joe in MI, 02-01-2008 12:56:04
Hey, thats what I was doing today, gosh, it took awhile to get that crud out of the inner pipe, close to the oil bath. The wadding at the bottom was plugged pretty good, top roll was clean though. Finally got it all clean and ready for paint!!
Richard Kelley
02-02-2008 07:42:52
 Re: air filter in reply to tiny-t, 02-01-2008 13:04:22
Thank you I cleaned the screen and cleand out the pan but did not look at the intake etc will do that as soon as it stops raining
tiny-t
02-02-2008 13:25:44
 Re: air filter in reply to Richard Kelley, 02-02-2008 07:42:52
I'll tell ya what, if you look down in that inner tube of the canister, wow, I had to work at getting that caked up stuff out. soaked it all in a bucket of simple green overnight, and then it came out with a thermos brush!!
