Rolling out of the dog house
WhiskyDog
02-03-2008 18:08:46
I had to have this 8n after all we share about the same birthday, It was a non runner sat out in the weather and had that old rusty look, but seemed to be mostly all there. Took the engine to the machine shop, then cleaned the rest of her while waiting. a quart of rusty medal primer, then a gray coat and finally a quart of red. Fired up yesterday worked out a few bugs and rolled her out today, babys' first day out in 2 months. Thanks to all that post the information here. It has helped me alot. not only is this tractor as old as I am it is sometimes as stubborn.
ToMater
02-04-2008 19:10:40
 Re: Rolling out of the dog house in reply to david heath, 02-03-2008 18:08:46
WhiskeyDog why you got your rear treads head'n in that direction?
whiskyDog
02-05-2008 02:09:01
 Re: Rolling out of the dog house in reply to ToMater, 02-04-2008 19:10:40
Tomater I just put them on quick and didn't look at them, the front end is going to have to be moved also, its to wide. It was not running when I got it and I was wanting to check it all out. the lift won't work in the draft position, I forgot to paint the vent for the air filter. I haven't put on the lights and wired them yet. its not charging, A few odds and ends to tie up. I still have a while before plowing time.
GB in MT.
02-03-2008 20:09:38
 Re: Rolling out of the dog house in reply to Jim SC, 02-03-2008 18:08:46
W....D...; We would like to see pictures!!!!!
Gary :)
GA Dave
02-03-2008 19:12:34
 Re: Rolling out of the dog house in reply to Dan, 02-03-2008 18:08:46
Picture missing? David.
whiskyDog
02-04-2008 14:52:49
 Re: Rolling out of the dog house in reply to GA Dave, 02-03-2008 19:12:34
third party image
Yeah I tried to post a picture. worked OK on the test page, sure thought I could figure it out but it didn't work for the forum. I'll try again
whiskyDog
02-04-2008 15:16:43
 Re: Rolling out of the dog house in reply to whiskyDog, 02-04-2008 14:52:49
third party image
Check out run up, by test driver, Crank em up Morgan.
whiskyDog
02-04-2008 15:08:08
third party image
in work next project in back ground a 640 needs a clutch and rear main seal, so far.
