Order Ford 8N Parts Online
things to do to his new 8N ?
osweld
02-04-2008 19:02:42
Ok buddy jsut bought this 52 8N wondering what things to do. It runs well but I told him to chg the oil and filter. It doesn't have a thermostat.
Should he chg the antifreeze, upper and lower hoses, thermo, plugs,wires,cap,rotor,condensor,
tranny fluid ?
Or just run it if it runs well ?
Thanks for the ideas and help he doesn't have a comp so im the go between.
Bruce (VA)
02-05-2008 06:32:17
 Re: things to do to his new 8N ? in reply to osweld, 02-04-2008 19:02:42
Do your buddy a favor & print the link below, "50 Tips" for him. Tell him to read #25. That explains why the engine needs a t-stat. Also, #39 will tell him what manuals he needs.
Too Tall
02-05-2008 04:57:00
When I first got mine I changed:
Oil and filter (6 qts)
Transmission fluid (5 Gal)
I also added a thermostat.
Checked my radiator fluid to verify freeze/boil point and then top off radiator to 1 inch below the top of the radiator.
In my mind, this was the minimum that needed changing as I didn't know it's age.
Everything else has been used till it broke and then replaced.
TooTall
Den N Ms
02-04-2008 19:43:14
Change the oil & filter and run it.Dont throw parts and money at it that it dont need.
