center axle cracks
8n-charley
02-05-2008 14:18:44
Seems every time I clean off grease something else is broke, this old girl will cost me an arm and leg before done.
Is it possible to repair the cracks in the center axle. Just sandblasted it and the cracks showed up. They are not to big at this time. Need advice on what to do. Thanks in advance for all your help.
third party image
third party image
trucker40
02-06-2008 21:23:07
 Re: center axle cracks in reply to 8n-charley, 02-05-2008 14:18:44
Those look bad.Drill a hole en the end of them v them out,weld them with a mig.I would make a couple of plates out of 3/8 maybe and reinforce that area while I was welding.Just cut them to where they lay in there good and weld them so if it does break there,you have the plate holding out past the cracked place.You would want to preheat it before you weld it.I would heat it not red hot but hot in a circular motion out past the crack some.Plus when I got it welded I would grind it smooth on top which makes the weld stronger and keeps it hot too for a while.I would weld the reinforcement plate before it cooled very much,just 4 or 6 2 inch long beads,maybe a few more if that didnt look like enough,to hold in case it breaks there.If when you grind on the metal sparks come off like normal its cast steel which you can weld with mig and 7018.Migs best.Thats just my opinion,I could be wrong.There is also the chance it will crack into a bunch of pieces as well,so you might start looking for another one.If it survives all that welding without any cracks it will most likely last a long time.
Mark Pearce
02-05-2008 22:58:59
Charley, If it were me I'd look into finding another one. But you know everyone says I'm crazy and way way too much a perfectionist. You could have the welding shop beaf that sucker up while they are at it. Make it stronger than before by adding some extra metal. That's if you go the weld it up route.
Mark.
John Smith8N
02-05-2008 19:31:53
third party image
Those cracks are very, very common on 9N and 2N axles but they are rare on the 8N. Which one of these axles looks like yours?
8n-charley
02-06-2008 05:23:53
 Re: center axle cracks in reply to John Smith8N, 02-05-2008 19:31:53
john, got it wrong, the bottom one, heres a pic
third party image
John Smith8N
02-06-2008 06:06:41
 Re: center axle cracks in reply to 8n-charley, 02-06-2008 05:23:53
Ok, you've got a 9N front axle, not 8N. Kind of suspected that with all the cracks.
8n-charley
02-06-2008 06:28:39
 Re: center axle cracks in reply to John Smith8N, 02-06-2008 06:06:41
john, can that 9naxel be replaced with a 8n?
8n-charley
02-06-2008 03:41:46
John, The top one is like mine, but it has the grease fitting.
8n-charley
02-05-2008 19:03:29
Thanks to you all, there is a good welding shop down the road that does a lot of farm equip and trucks, will take it down there tomorrow and see what he can do. Without this board I would not have tried to restore the 8n on my own.
Den N Ms
02-05-2008 18:55:02
8n-charley,My 2N axle was cracked just about identical to yours.I really didnt notice it till I glass beaded it.I veed it out and welded it up with a mig welder and 75%25% c02-argon gas.It welded up great.The axle is malleable iron and will weld up fine without cracking.
36 coupe
02-06-2008 01:28:21
 Re: center axle cracks in reply to Den N Ms, 02-05-2008 18:55:02
The axle is a steel forging,mallable iron would not take the pounding that a front axle gets.
Randy(PA)
02-05-2008 18:51:27
You would want to verify with a spark test, but the successor replacement axles are 1040 steel. A good welder can do the spark check and appropriately weld this for you.
Tom (Iuka80)
02-05-2008 18:39:28
John Smith has one listed for sale on his web site.
Hobo,NC
02-05-2008 17:17:00
I would look for a replacment,,, mite b wrong but would think they would B cheap,,, a good'n with no cracks would b better than a repaired one,,, if you don't plan on werk'n it then i mite repair it myself,,, sure would make a mess if it did break...
Dan
02-05-2008 16:48:42
My 1939 9N axle is cracked in that exact same spot. It is not down into the flat part like yours, only across the top flange. I plan on just putting it back on.
Dan
8n-charley
02-05-2008 15:47:49
 Re: center axle cracks another view in reply to 8n-charley, 02-05-2008 14:18:44
Heres another view, will post picture when repaired, thanks for the replys.
third party image
third party image
Dunk
02-05-2008 15:41:51
I sure am glad that I didn't sandblast mine and find cracks like that!!
Of course, I didn't sandblast mine, and have NO idea if it has cracks like that or not.
I can't for the life of me, figger out what would have caused cracks like that, on what *I think* to be the top, one would think cracks would be on the bottom, if anywhere.
Keep us posted!!
russbWA
02-05-2008 15:31:13
Charley, I was wanting to wonder what year N you have. Cause I see the grease zerk, which mine does not have.
Dell (WA)
02-05-2008 18:43:28
 Re: center axle cracks...NO GREASE! ! ! in reply to russbWA, 02-05-2008 15:31:13
NO GREASE the front axle center pin. Why? 'cuz grease attracts DIRT and turns into GRINDING compound ..... ...Dell
Den N Ms
02-05-2008 19:08:43
 Re: center axle cracks...NO GREASE! ! ! in reply to Dell (WA), 02-05-2008 18:43:28
I guess thats why they put grease fittings on on disk harrow boxings&bushings.My 2N has had a fitting there for I know 50 years .The grease will push out any dirt that gets in there. Go figure.
Dunk
02-05-2008 18:51:48
 Dell!! The Least of our Problems!! in reply to Dell (WA), 02-05-2008 18:43:28
What do you think about the cracks?!!?!?
Dayum, it would take 70 years for the abrasive dirt, to do anything close to as bad as those cracks!!
Dunk
02-05-2008 15:43:52
 Re: center axle cracks in reply to russbWA, 02-05-2008 15:31:13
My '49 doesn't have it either.
I may be wrong, but I think that zerk was an aftermarket add on.
8n-charley
02-05-2008 15:39:15
Its a 47 8n
russbWA
02-05-2008 14:59:39
The fix would be welding;
Drill a hole at the end of the crack(s) ~1/4 inch diameter. (this negates the focus of two different forces from one concentrated area to a wider area)
V out the crack with a grinder.
Heat the whole thing up to ~ 500 F.
Use the correct rod for what I assume is cast iron.
Cool slowly as reasonably possible after welding.
osweld
02-05-2008 14:56:47
man too bad... how common is this and how costly and hard to fix ?
