PTO
Rick In VA
02-06-2008 18:06:40
Hi All!
I want to use a PTO pulley on my 9N but finding one with the 1 3/8 shaft is almost impossible, and when I have seen one, it cost a fortune. I converted my 9n to the 1 3/8 shaft PTO when the seal went bad on the original, now I want to put it back! Can you get a modern seal for the older PTO shaft? And if so, where? Many thanks!
Rick
Rick In VA
02-07-2008 09:41:14
 Re: PTO in reply to Rick In VA, 02-06-2008 18:06:40
Thanks All,
Dunk, I'll take you up on your offer to see what you can find out. Old-9 if something easier doesn't turn up, I'll be getting back to you!
JimmyJack, thanks for sharing what you did, I want to try it the original way first but if all else fails...
Rick
old-9
02-07-2008 05:49:06
Yes they still make the right seal, but not cheap. New Holland can order it I think. If not I can get you one. Email open. Joe
Jimmyjack
02-06-2008 20:37:41
I had the same problem one time, and took the pulley and mounted it on the saw rig. I ran a short belt from pulley to pulley for a safety device in case something pinched. Then I ran a sort pto shaft from the tractor to the pulley on the saw rig. Now any three point can use the sawrig and I dont have to loan out the tractor too. It works just great.
Dunk
02-06-2008 18:14:52
Rick, I am sure that you can convert to the newer model seal.
If someone doesn't tell you how, I will do my best to look that up for you in the AM, and post it.
I may try now, no guarantees.
