Hard starting when hot
Roger
06-02-1999 19:37:10
My 8n runs fine when first started, but after it's hot, it loses power and will not restart if turned off. Does anyone think it's carb or ignition? Are they prone to vapor lock with fuel line right above motor?
Po Folks
06-03-1999 18:23:16
 Re: hard starting when hot in reply to Roger, 06-02-1999 19:37:10
Ignition. I would replace the condenser first and if that didn't fix it, coil would be next. You can check gas by taking the screw out of the bottom of the carb. If it quits and gas runs out bottom of the carb. it probably is not a gas problem.
Dell (WA)
06-02-1999 21:19:43
Roger..... .N-tractors are not known for vapor locking, how ever, the gas tank vent hole has been known to get plugged up by mud daubers, just release you gas cap to re-vent your tank. But I don't think this is your problem.
A frequent contributator to the N-Board, claims most carb problems are found and solved in the ignition system. I believe this will be your case.
There is an obscure electrical component that is frequently overlooked that after about 1/2 hour of "warming up" causes misfiring and power loss caused by low battery voltage to the ignition coil. This component's internal electrical contacts get gunked up which causes them to heat up and when heated up, reduces the battery voltage
to the ignition coil causing loss of power and inablility to start untill cooled down for about 1 hour or so.
Next time this happens, try an aligator clippie jumper wire to jump around and by-pass the IGNITION SWITCH. If your tractor starts right up, you have found you problem.
If it doesn't start up, you have also found your problem, the dreaded ignition coil shorting out the turns when heated up syndrome. The fix is to replace the ignition coil.
And while you are at it, you just might want to consider replacing your points and condenser, set to specs.
Hope this helps..... ..Dell
Bob W
06-03-1999 05:00:15
 Re: Re: hard starting when hot in reply to Dell (WA), 06-02-1999 21:19:43
My 8N did the same thing. And like Dell said it was a bad coil. I put a new coil on and all was good again.
