what do the stablizer arms look like that are needed for bac
osweld
02-07-2008 17:13:21
I hear people on here say you need stabilizer bars to bckblade snow and dirt, can someone post a pic of these and where you get them
Dan in CO
02-07-2008 20:04:27
 Re: what do the stablizer arms look like that are needed for in reply to Colin King, 02-07-2008 17:13:21
On the screen you are looking at,left side where it says "Marketplace" click on tractor parts. select Ford New Holland. then click on "looking for 9N 2N 8N? click here. select your model Then select "Hitch/Drawbar" scroll 1/3 of the way down the page to the stabilizer kits. There are 2 of them light & heavy. The better one is the heavy $54.90
Danny in CO
02-07-2008 19:23:05
 Re: what do the stablizer arms look like that are needed for in reply to osweld, 02-07-2008 17:13:21
Osweld,
There are 2 types of stablizer bars. One type mounts under the axle in line with the lift arms. These keep an implement from moving side to side. The other type hooks to the top link mount point and keep the lift from moving up or down. These would be used with a trailer to keep a load from pushing up the hitch. In the picture by GB, the arrows are pointing at the toplink bars. You can see the other type on the left side down low.
To plow snow, you need the bars that mount under the axle to keep the plow from moving side to side.
Hope this helps,
Danny
Danny in CO
02-07-2008 19:26:22
 Re: what do the stablizer arms look like that are needed for in reply to Danny in CO, 02-07-2008 19:23:05
Never mind, I read GB's post better. He points to each type.
Danny
Dan in CO
02-07-2008 17:28:18
Osweld:
Scroll down to the "Stabilizer Bar" post and see GB in MT's reply to you in that thread. He posted a very descriptive picture of the bars mounted on his tractor.
dan in co
02-07-2008 17:24:51
Here is a link to the picture of the stabilizer bar kit sold right here on this site.
osweld
02-07-2008 19:47:22
 Re: what do the stablizer arms look like that are needed for in reply to dan in co, 02-07-2008 17:24:51
so I would need this kit ? How much is it ??
keennt
02-08-2008 06:58:03
 Re: what do the stablizer arms look like that are needed for in reply to osweld, 02-07-2008 19:47:22
Hint: They come in different lengths, so be sure to measure from mounting point to implement pins when connected to the lift arms..... .
keennt
02-08-2008 07:11:18
 Re: what do the stablizer arms look like that are needed for in reply to keennt, 02-08-2008 06:58:03
My previous post said to measure the distance..... That's if you already have the mounting brackets on the axle housing...
If you have to mount the complete kit, the brackets have holes already drilled so you can get the right length....
