Order Ford 8N Parts Online
How much disc for 8N?
ToMater
02-10-2008 13:38:01
I'm wanting to put "Mater" my 47 8N to work this spring discing up some old fields. I've been looking at new and used discs for a while but I really don't know anything about what I'm loking at. :?: How much of a disc can an 8N handle? What is the reason for some discs having notches? If I'm buying used what should I be looking for that would help me establish a condition? Any help would be great. :idea: Directing me to some material on working the ground would be a plus.
jon
02-11-2008 16:11:48
 Re: How much disc for 8N? in reply to Danny in CO, 02-10-2008 13:38:01
AM-Seb said: (quoted from post at 14:55:43 02/11/08) Re Jon's fold over question: I have a Ford Series 22l disc. The Operator's Manual says: "To fold over for bush and bog work remove Bolts No. 21 [4] and fold rear frame and gangs over front frame." It then lays on the angled bar between the front of the rear frame and near the top of the disc's A-frame where the upper link is. I've used it like that only a couple of times as in normal use for garden preparation in my soil fold over is not needed. Angelo
I appreciate that. Mine can be folded but I never have done it before. It's so long I thought it might change the leverage of it if I had to go out on the road. The way it is now it's all brake steering!
JMOR
02-11-2008 14:11:20
 Re: How much disc for 8N? in reply to Bruce (VA), 02-10-2008 13:38:01
Other than obvious broken/bent/missing parts, I think bearings are costly & a lot of labor to replace, at least on some models.
larry cook
02-11-2008 05:10:14
 Re: How much disc for 8N? in reply to ToMater, 02-10-2008 13:38:01
agree with soundguy, different scenarios. i use a 8n but also have a 640, i have a 5.5" that works well for me. of course i use it on two places. went with the smaller disc so i could haul it to the ranch that is 45 miles away. i use it more with the 640 than the N, the N is usually pulling a shredder around on the small jobs i do closer to home.
larry cook
Mr. Bob
02-10-2008 20:08:44
I have an old 8' dunham drag disc converted to 3 pt. hitch that I ues with my '46 2N. Rear tires(12.4x28) are loaded with a 135# wheel weight on each wheel. Bumper on front weighs 100#. I've had no problems on the rolling ground where I've used it. I just use a little "common sense" when turning uphill with disc lifted. Disc weighs around 8-900#. Mr. Bob
russbWA
02-10-2008 18:05:15
Discs are pretty heavy. My Ford series 201 6 1/2 ft is just a bit heavy for EvelyN. When I got the disc it had an extra 600 lbs of elevator counter balance weights attached, which I removed. It had been pulled behind a 45 hp tractor. It must have cut like crazy at almost double its regular weight.
I won't put any extra weight on it. Rather just go around another time.
jon
02-10-2008 17:51:46
Brian Bell said: I lucked up and found an old Dearborn 10-135 fold over disk local for reasonable money.
What was the purpose of a fold over, just easier to transport?
AM-Seb
02-11-2008 10:55:43
 Re: How much disc for 8N? in reply to jon, 02-10-2008 17:51:46
souNdguy
02-10-2008 15:00:57
as the other guys said.. 6-6.5' works great.
lots of variables on gangs, blades, soil, frame / weight.. etc...
soundguy
Brian Bell
02-10-2008 14:52:14
I have either a 6 or 6.5' that I pull behind my '51 8N. It pulls it pretty good. The notched disk blades help cut up the soil better than the smooth disks. My disk has notched blades on the front and back gangs. I lucked up and found an old Dearborn 10-135 fold over disk local for reasonable money.
old
02-10-2008 14:51:46
A 6 foot will work real good unless its real heavy. I use one on my 9N and 8N but had to take one of the weights I had on it off because the front end was to light for it
