Order Ford 8N Parts Online
8N Pinion Change Problems
Pace F20s
02-10-2008 15:10:33
I am (or was going to try)replacing the pinion in my 52 8N because of some damage on it. I have a good one and the ring gear doesn't look too bad, and I don't have a ring gear. When I tighten the left axle housing, the ring gear and pinion bind. Loosening the axle housing about the thickness of a thick gasket releases the binding. According to the book, there is no backlash adjustment. The book doesn't say anything about replacing them as a set. Anybody got any ideas? Thanks
don b
02-11-2008 06:27:00
 Re: 8N Pinion Change Problems in reply to Dunk, 02-10-2008 15:49:09
Dunk....there was a revision to this statement.Tech bulletin says replacing in match sets is not required. don b
Pace F20s
02-10-2008 18:49:27
Thanks for the information.
