Order Ford 8N Parts Online
Wagner Loader 8n Front Pulley Assembly
Eric Nichols
02-11-2008 11:28:54
I purchased a Wanger loader 110 model I believe and have all the brackets and front pump for this loader. However I am missing the drive shaft for the hydrolic pump for the loader which runs off of the crankshaft I was told, and the hub and pin assembly. Does anyone have any knowledge where I could find the parts to drive the pump for the loader?
Archie in KY
02-11-2008 16:36:29
 Re: Wagner Loader 8n Front Pulley Assembly in reply to Eric Nichols, 02-11-2008 11:28:54
I had a TO-20 with a skyline loader The connection parts looked just like the ones Bob sent you. My boy still has the tractor and the control valves went bad so he decided to replace all the hydraulic components with new upgraded stuff and it isn't working as well as it did to start with, so I wouldn't recommend that. Most of current problems are with the new pump. If you have a good pump and a set of original valves that you would like to sell let me know.
TheOldHokie
02-11-2008 12:16:58
[quote="Hobo,NC"](quoted from post at 13:09:33 02/11/08) Drop me a email and we will cipher it out,,, If you need the threaded set up that uses the 4 pin hub,,, TOH has this set up,,, I sent it to'em to make the proper crank bolt,,, he's keep'n it for payment for some werk i had'em do,,, so contact TOH for that set up and the right crank bolt to retain the pulley,,, I am sure its 4 sale
/quote]
Correction - it was sent as payment for some "werk" I have yet to do :oops: It is the pulley, hub, and splined shaft flavor and is indeed for sale including an appropriate crankshaft bolt.
TOH
Hobo,NC
02-11-2008 12:09:33
third party image
Bob
02-11-2008 11:31:42
THIS very website has the front pulley and drive parts in the "On-Line Store" over to the left of this page.
Eric Nichols
02-11-2008 11:35:24
 Re: Wagner Loader 8n Front Pulley Assembly in reply to Bob, 02-11-2008 11:31:42
Bob,
I called them today and they wanted to know the spline and things of that nature which I was unable to give them. Could you assit in part numbers purhaps? All I have is the pump on the loader I need everything else. I would really appricate it!
Bob
02-11-2008 11:40:12
 Re: Wagner Loader 8n Front Pulley Assembly in reply to Eric Nichols, 02-11-2008 11:35:24
You should be able to get the pulley and the matching "coupler half" and a shaft that fits the coupler half from this site.
That would get you out to the pump. Do you have THAT coupling, or just half of it?
Hopefully, HOBO will see this, and post his excellant photo of the matching parts and part numbers.
