Lift arm pins?
redleg
02-11-2008 11:55:09
Tried to remove my lift arms from the diff to fab up a stabilizer bar this weekend and one side spins freely and seems to have a little fluid around it. How are these attached? Do they press in? Threaded?
redleg
02-12-2008 14:21:22
 Re: Lift arm pins? in reply to redleg, 02-11-2008 11:55:09
Well, it just gets better... :shock: :lol:
Thanks for the pics dunk.
Sorry Dunk, it's an 8n. I belong to a truck forum that encourages your vehicle description and modifications in your signature to speed up question and answers. Others don't like it, I think because it slows the loading for dial up or appears cluttered. I didn't see much of it here, and I goofed anyway and assumed they would all be the same. I'm gonna put it in my sig. anyway since there's not a lot to add yet anyway.
Don
redleg
02-12-2008 12:59:44
Well, tomorrow I'm gonna try to go pick up a john deere. 3 pt. snowblower from a friend. Might be on the big side, it's funnel shaped and single stage. Instead of an auger, it looks like flail blades in line with the pto shaft from the picture? That should help make use of my lower horse power than the 60 it came with. Should relieve some ramming of the pins a bit. When the time comes, he's confident he could weld up the hole and redrill it the right size for the pin if it's sloppy. He's been welding truck frames and industrial equipment for 30 years. He's in Kalamazoo if needed... shameless plug intended. He alsoseems to be confident on welding the cracked diff case for me. Seems to think makeing a little hook in the beed at the end of the weld is better at preventing the crack from returning, than drilling the ends of the crack.
Dunk
02-12-2008 13:21:32
 Re: Lift arm pins? in reply to redleg, 02-12-2008 12:59:44
No where do I see what tractor we are talking about here.
If it is an 8N the holes are tapered.
third party image
third party image
redleg
02-11-2008 13:19:23
Probably already too late... I'll watch for it, thanks.
redleg
02-11-2008 12:02:14
Greeeaaaat.....
Thanks Bob. Hopefully it'll stay on til spring or at least if the nut falls off, hope it stays low and out of the gear. I aint breaking it open til the weather is warmer.
souNdguy
02-11-2008 12:08:10
 Re: Lift arm pins? in reply to redleg, 02-11-2008 12:02:14
Beware.. if it is loose enough to spin freely and seep.. it is loose enough to start ovaling that hole it fits in.. once it wallows that out enough you will be in for a bigger repair.
soundguy
Bob
02-11-2008 12:00:25
There's a keyed "castle nut" INSIDE the differential housing.
