Order Ford 8N Parts Online
Testing a Coil for 8N
zinala107
02-11-2008 20:31:26
Can anyone help? I"ve got an 8N that has been converted to 12volt. i"ve tried 6 coils that were new in a box. I had purchsed them in the past, and had them put away for when i needed them. All 5 out of the 6 coils weren"t anygood, i finally put one on, and the tractor cranked right up. I was beginning to think it was something else.
Is there anyway to test these coils to see if they are good or not. i can"t believe they went bad, just being in the box, but maybe so. Is there any tester available to test the coils.
Thanks.
MikeT
02-12-2008 07:41:20
 Re: Testing a Coil for 8N in reply to zinala107, 02-11-2008 20:31:26
third party image
This aught to work as an initial test of a coil. When you rapidly touch and release the wire to the negative post of the battery you should see a hot blue spark at the plug gap. Don't leave the wire connected else you might melt the coil.
This test would only show you that the wiring inside the coil is intact. Would not tell you if the coil is putting out recommended voltage.
S Russell (TX)
02-12-2008 05:57:14
Z, Yes they can be tested. Automotive equipment has changed but the SUN Tune-up and Test equipment I use to sell in the lae 70's allowed for testing the coil off the vehicle.. So would the ALLEN and other makes of Auto test and tune-up equipoment. I use to carry an old Bosch coil with me to test customers machines for them.
soundguy
02-12-2008 06:54:29
 Re: Testing a Coil for 8N in reply to S Russell (TX), 02-12-2008 05:57:14
SR.. there isn't a real EASY test.. unless you are going to ship your ignition alylizer all of the us for people to test their tractor coils.
The best tester is the tractor distribuitor itself in most cases.
Tractor ignition systems are NOT hard to work on.
Soundguy
zinala107
02-12-2008 05:47:33
thanks for your help. yes, it is a front mount distributor.
i've also replaced the distributor to rule that out. I took it off a working tractor, and also tried a new one. plugs are good, and wiring seems fine. i will try the yalls advice. thanks.
soundguy
02-12-2008 05:30:58
Generally.. the front mount coils which are tar or epoxy potted don't go bad from setting.. I'd guess it was an electrical contact problem as the other posters mentioned.
soundguy
Dell (WA)
02-11-2008 20:59:28
Zinala..... .Dave is correct, the biggest cause of sparkie problems with the 4-nippple squarecan coil is the dangling springy-thingy and it frequently needs a gentle stretch to fit the hollowhead contact screw down in the hole ontop the distributor.
Unfortunately there is NO eazyway to otherwize test the non-running ignition system. Howsomevers; you can test the running ignition system with my calibrated sparkie tester made from enny ol'sparkie by bending out the side electrode for a full 3/16" gap and grounding the shell and connecting enny sparkie wire and crank yer engine and watch for a blue-snott sparkie to jump the gap. Iff'n its a wimpy yellowish-orangish sparkie, yer coil probably ain't nogood. But I'd check the points gap first for invisible corrosion and reset the points gap to 0.015".
For reference purposes, my eazy starting 6-volt 52 8N roundcan sparkies will jump a full 3/8" gap. ..... .HTH, Dell, yer self-appointed sparkie-meister
36 coupe
02-13-2008 02:46:44
 Re: Testing a Coil for 8N in reply to Dell (WA), 02-11-2008 20:59:28
I test coils on the bench often.Just set up a spark gap and interrupt the primary voltage,a condenser should be in the circuit.
GA Dave
02-11-2008 20:37:00
 Re: Testing a Coil for 8N in reply to tiny-t, 02-11-2008 20:31:26
I assume this is a front mount. The pigtail probably needs streched on the others. If side mount Delete this post. David.
