Remove front cover
8n-charley
02-12-2008 08:36:49
Is it necessary to remove the crank pulley to remove the front cover? part # 6019. front dist (8 1/2n) seems to be a bit of both 8n and 9n. I have all the bolts off the govener support plate etc.. it is cast so didn't want to bfh it. thanks as always.
Dell (WA)
02-12-2008 08:58:40
 Re: Remove front cover in reply to 8n-charley, 02-12-2008 08:36:49
Charlie..... ...what Dunk sezs ...and... tip: stuff some soft 1/4" rope down enny sparkie hole to stop the crankshaft from doing a 360 against the cylinder head. Why? 'cuz that BIG crownhead bolt that holds the pulley on is torqued to 150ft/lbs ..... ...Dell
8n-charley
02-12-2008 13:33:43
 Re: Remove front cover in reply to Dell (WA), 02-12-2008 08:58:40
Thanks Dunk and Dell, will get out there tomorrow and give it a try.
Dunk
02-12-2008 08:43:03
If I recall correctly, something makes it really hard to remove without removing the pulley.
Also I think there are at least 2 bolts that come up from the bottom, if you miss them you will break it.
8n-charley
02-12-2008 15:33:55
 Re: Remove front cover in reply to Dunk, 02-12-2008 08:43:03
You are right on Dunk, I missed the two bolts on the bottom, will try tomorrow to get it off, right now its Miller time.
