5/8 Pulley for GM alternator
Phippsburgh
02-14-2008 15:57:45
Does anyone out there have a part number, NAPA or otherwise, for the proprer 5/8 pulley for 12 volt conversion on 8N to a GM 10SI alternator. If not, does anyone have the proper dimensions at a glance, or should I try to measure on my own? Thanks
Kevin in MN
02-14-2008 19:37:09
 Re: 5/8 Pulley for GM alternator in reply to Phippsburgh, 02-14-2008 15:57:45
the si was part of the number in the Tisco web site. I order from local dealer had the next day $30.00 .
Hobo,NC
02-14-2008 18:40:59
With out look'in I am gonna say 98NAA5825 is the correct one,,, I keep it in stock,,, YT mite have it,,, taint cheap but correct ,,, for your application
Duner Wi
02-14-2008 17:25:40
MF # 1750509M1.
Phippsburgh
02-14-2008 19:21:22
 Re: 5/8 Pulley for GM alternator in reply to Duner Wi, 02-14-2008 17:25:40
Is that MF as in Massey Ferguson?
Duner Wi
02-15-2008 06:57:01
 Re: 5/8 Pulley for GM alternator in reply to Phippsburgh, 02-14-2008 19:21:22
Yes it is. Also any 1 man alt. gen, starter shop should have a pulley.
Kevin in MN
02-14-2008 16:44:24
Tisco Part number 98NAA5825 SI Number 968471 Pulley
Phippsburgh
02-14-2008 19:30:48
 Re: 5/8 Pulley for GM alternator in reply to Kevin in MN, 02-14-2008 16:44:24
Where do you find Tisco parts, through a dealer, right? And what does the SI number mean? Is that a different supplier? Thanks for your quick response. I am trying to get it ordered tomorrow. You guys really save me some time!
Dunk
02-14-2008 16:09:21
I used the pulley off my old genny, "bolted" it right on my alternator.
It could stand to be a smaller diameter, but it has been doing it's job for over 20 years, it is a 10SI that I had rebuilt to be 6v, posi ground, one wire.
Hang on and I will see if I am able to look up the part number.
Dunk
02-14-2008 16:18:41
 Re: 5/8 Pulley for GM alternator in reply to Dunk, 02-14-2008 16:09:21
Here is what I can find..
NOT SERVICED  Pulley, Generator, Years: 01/01/1948-12/31/1949 NS $0.00 Call
PULLEY  Pulley, Generator, Years: 01/01/1950-12/31/1952 8N10130A $57.37 Avail in 3-5 days
