Order Ford 9N Parts Online
non startin 9n
aggrevated 9n o
02-16-2008 14:37:09
In the middle of bladin the snow she sputtered and died so we drug/pushed her into the garage where I dried out the front mount cap but will not start turns over fine, battery is freshly charged, but I have no spark any ideas? I just replaced the plugs and wires and was running great until she died in the middle of my driveway thanx for your help !!!!
Dan in CO
02-16-2008 15:16:00
 Re: non startin 9n in reply to aggrevated 9n owner, 02-16-2008 14:37:09
Aggrevated:
Not an expert here, but these are the things I would look for / try:
- Jumper wire across the ignition switch to see if that results in spark, They can go bad & prevent juice from getting to the coil
- Pull the coil & stretch the little coil wire that seats on the top of the distributor. They can get weak & open up the circuit.
- Pull a clean piece of paper bag between the points to clean them
ZANE
02-16-2008 14:40:55
The best thing to dry out a distributor cap is pure oxygen. It is super dry and will dry the wettest cap out in a couple of minutes.
I learned this trick when I worked master mechanic on construction. An old welder told me about it. It works!
Zane
