Carb spacer on a 621
Andy MN
02-16-2008 15:36:43
It seems that the carb spacer is missing and they used a homemade thin paper gasket. And when I tighten the nuts the studs but up against the manifold, alowing an air gap between the carb and manifold. Can I get one of those spacers ? I thought about making one but that's a lotta work . I looked at carb kits and they come with a fairly thin gasket too. And I thought about shortening the studs, I don't realy wanna do that.
Dunk
02-16-2008 20:39:19
 Re: Carb spacer on a 621 in reply to sfurn 52 8N, 02-16-2008 15:36:43
Andy MN said: (quoted from post at 20:36:43 02/16/08) It seems that the carb spacer is missing and they used a homemade thin paper gasket. And when I tighten the nuts the studs but up against the manifold, alowing an air gap between the carb and manifold. Can I get one of those spacers ? I thought about making one but that's a lotta work . I looked at carb kits and they come with a fairly thin gasket too. And I thought about shortening the studs, I don't realy wanna do that.
Ummmm... Ummmmm...
Change the studs?
russbWA
02-16-2008 19:15:51
 Re: Carb spacer on a 621 in reply to Andy MN, 02-16-2008 15:36:43
Andy, maybe you can make a heavier gasket or gaskets. Card stock or a milk carton come to mind. HTH
