PTO WILL NOT LIFT
99F250
02-17-2008 07:00:20
I WAS OUT BLADING MY DRIVE WITH MY 8N AND MADE ONE SWIPE STARTED TO LIFT THE BLADE AND MY TRACTOR STOPPED WOULD NOT GO FORWORD AT ALL SO I PUT IT IN NUTRAL LIFTED THE BLADE AND THEN PUT BACK IN TO 1ST AND IT TOOK OFF OK. LET BLADE BACK DOWN AND TRIED TO GO FORWORD AGAIN AND HEARDA POPPING NOISE AS IF IT WAS BOUND UP SOME HOW. THE RIGHT REAR TIRE IS THE ONLY ONE THAT WAS LOCKED UP IT WOULD NOT MOVE. WHAT DO YOU THINK IS WRONG WITH IT?
redleg
02-18-2008 18:02:11
 Re: PTO WILL NOT LIFT in reply to 99F250, 02-17-2008 07:00:20
Wondering if the PTO lever would cause that if it was bumped or getting sloppy?
DON TX
02-17-2008 18:11:44
Make sure the blade isn't catching on the tire. If it's at the right angle it may be catching. The ripper on my box blade cost me a week old rear tire. Still make me mad to think about it. HTH
DON TX
99f250
02-18-2008 02:53:56
 Re: PTO WILL NOT LIFT in reply to DON TX, 02-17-2008 18:11:44
i know its not that, when this happened it sounded like a gear popping. thanks
ZANE
02-17-2008 17:36:34
You may have a problem in the differential with it making a popping sound. If it were the brake on one side the other side would spin the wheel.
Don't keep on trying to make it go. You could damage the differentail housing beyond repair.
Remove the left wheel, axle and axle housing and then inspect the differential spider gears inside the differential and look good at the four shafts that are sandwitched inside the carrier. Also inspect the ring gear and pinion for damage.
Zane
Bruce (VA)
02-17-2008 13:23:29
Take a close look at the right brake pawl. If it's not stuck, get the rear wheels off the ground & spin them by hand one at a time. Post back w/ any more questions; lots of folks here can help you fix it.
MikeT
02-17-2008 12:47:29
Sounds like hydraulic lift is working. But, is the right brake locking up maybe? Press down on the brake pedals and see if they 'feel right'.
Maybe you could block the front wheels, put tractor in neutral, jack the rear wheels off the ground and see it the tires can be spun by hand.
Iowaman
02-17-2008 08:23:30
It's the operater.
Bruce (VA)
02-17-2008 13:20:57
 Re: PTO WILL NOT LIFT in reply to Iowaman, 02-17-2008 08:23:30
Maybe so, but the man asked a legitimate question & deserves a response, not a smart@ss comment.
99f250
02-18-2008 03:01:48
 Re: PTO WILL NOT LIFT in reply to Bruce (VA), 02-17-2008 13:20:57
thanks Bruce i think i know who that is.
