GB in MT.
02-18-2008 07:05:02
Re: 621 Zenith carb. in reply to old, 02-17-2008 16:39:55
Andy MN said: (quoted from post at 21:20:54 02/17/08) I see on the OLDER carbs there is a T handle lower adj. screw, But on mine there is a plug with a seal , Is there an adjustment screw hidden in there? And if there is it is blocked by the sediment bowl. OH gremlins ran off with my f04 manuel , can't find anywhere . Would sure be nice to know how this works . |
Andy; Not knowing what model on tractor you have, puts me in a situation, where I am reluctant to answere your questions. I have never worked on your type of carb., but the M/S carbs., I have done quite a few of!!
I suspect that the "T" handle lower adj. screw, that you are refering to, is NOT an adj. screw at all, but is an add-on butterfly drain, used to drain the carb. bowl of contaminents in the gas. A lot of the "N" series guys are asking me to install these valves, to make it easier to check gas flow, from the tank to the carb.!!!
Getting back to your probs. with your carb., I think you should try to find instructions on that specific carb..... That will insure you to have them for taking appart the carb.
It sounds to me that some kind of dirt/particles are in one or more of the jets in the carb., making that carb give ya fits.
Like I said, try to get the inst. on your carb., then follow them to clean out you problems.
Sorry I could not help more!! :( :oops: Gary :roll:
