proofmeter
adam 8n
02-17-2008 17:09:03
Another question can i put a proofmeter on my 49 8n?
Brian Bell
02-17-2008 18:50:43
 Re: proofmeter in reply to adam 8n, 02-17-2008 17:09:03
Unless you just want the stock look of a proofmeter, go to Northern Tool and get a digital tach that is universal. They cost about 40.00 (cheap compared to the rest) and are fairly accurate.
Den N Ms
02-17-2008 17:19:59
Adam,Yes you could,you would have to have a proofmeter,a drive cable and a different governor with a proofmeter drive commin out of the back of it.
Bob
02-17-2008 17:18:04
IF it has a governor with the proofmeter drive at the back.
adam 8n
02-17-2008 17:19:40
 Re: proofmeter in reply to Bob, 02-17-2008 17:18:04
on the back of the gov. assembly?
betweent it and the engine?
Bob
02-17-2008 17:23:03
 Re: proofmeter in reply to adam 8n, 02-17-2008 17:19:40
The governor needs to have a threaded "nipple" at it's back end, to accept the tach cable housing, AND the appropriate shaft and drive sleeve INSIDE the end of the shaft.
adam 8n
02-17-2008 17:36:34
 Re: proofmeter in reply to Bob, 02-17-2008 17:23:03
well a new gov. assembly that accepts a proofmeter is about $250 - $300 so looks like i will do with out for now.
Thanks for th advise
