Most N brakes will apply if you pull up on the petal,,, sometimes by accident while back'n my leg will pull up on the pedal and apply the brake,,, any time i replace brakes they git a good break in run,,, cars git 7 to 10 stops from 35 down to 5MPH i do'em in sequence,,, On a N I stand on the pedal while drive'n,,, git'em hotter than forty hell,,, let'em cool and re adjust,,, never had a problem,,, well almost never,,, one thing I have had to do was back off on the adjuster a little more than I wanted to,,, run the tractor some and sneak up on the adjustment a little at a time till after some use got the brake pedal I wanted,,, new shoes and full adjustment has been sorta a problem so run'em a tad on the loose side till they seat in good Most brakes are extremely aggressive cold and have absorbed moisture,,, you mite try and use the brakes forward a few times,,, if it really helps then i would run it till you ware'em a little and git a glaze on'em,,, problem mite go away Then again thay mite have some contamination on'em like grease,,, problem will never go away
