wat does this lever do
philip stopczyn
02-22-2008 12:04:15
i have a 1948 8n there is a small lever under the seat i dont now wat it does
Dell (WA)
02-22-2008 13:08:25
 Re: wat does this lever do in reply to philip stopczynski, 02-22-2008 12:04:15
Philip..... ..the little lever under yer right kneezie is NOT a flush lever (grin) it is a selector for hydraulics. UP (vertical) is position control as in brushhoggin' and other general lifting jobs. Horizontal is DRAFT control for PLOWING. 9N's & 2N's don't have that lever, their hydraulics are ALWAYS DRAFT. Unless yer plowing with yer 8N, keep yer lever UP..... ..HTH, Dell
JMOR
02-22-2008 12:49:15
 Re: wat does this lever do in reply to Dunk, 02-22-2008 12:04:15
The small ~3 inch lever on top of the lift housing, when vertical is in POSITION CONTROL and when horizontal is in DRAFT CONTROL. It alters how the lift arms react to the Hyd Touch Control Lever.
ozark mike
02-22-2008 12:30:25
the one on the right is draft and the one one the left is pto
