Order Ford 9N Parts Online
non starting 9n
aggrevated 9n o
02-24-2008 07:37:06
i have a 6 volt system ive replaced plug wires,points(gapped at .015) cond., cap, and i have 5.6 volts tothe top of my coil ive checked the springy thing at the bottom and stretched it out a bit but still no spark ????? any suggestions thanx
Tom N MS
02-24-2008 07:55:39
 Re: non starting 9n in reply to aggrevated 9n owner, 02-24-2008 07:37:06
Copper strip going from points to springy thing screw is bad about breaking. Also the insulation located under the concave screw(where the springy tail contacts)will break down and cause a dead ground.
aggrevated 9n owner
02-24-2008 10:21:03
 Re: non starting 9n in reply to Tom N MS, 02-24-2008 07:55:39
thanx i'll check
