clutch pedal
pete/nv
02-24-2008 12:07:01
does anyone know, if the clutch is stuck would the clutch pedal come back up once it is pressed down?
Bob
02-24-2008 12:12:16
 Re: clutch pedal in reply to pete/nv, 02-24-2008 12:07:01
If the lined clutch disc is tuck to the flywheel/ pressure plate, the pedal will come up "as usual".
If the throwhout bearing carrier is stuck/rusted to the "tranny snout", the pedal WILL NOT come up normally.
pete/nv
02-24-2008 12:27:30
 Re: clutch pedal in reply to Bob, 02-24-2008 12:12:16
thank you
