Order Ford 8N Parts Online
8n carb
prestone
02-25-2008 17:06:52
gas dripped out from carb. rebuilt it & it still drips down to the ground. did i do something wrong or does it just need an adjustment? HELP
Dell (WA)
02-25-2008 18:32:29
 Re: 8n carb in reply to prestone, 02-25-2008 17:06:52
Prestone..... ..ALWAYS shut yer under the tank fuel valve OFF when yer done using fer the day.
We are finding that the brass float valve LEAKS BEHIND the valve even though it has a sealing washer. Ya really gotta HONK DOWN on that seat with BIG HOLLOW-GROUND flatblade screwdriver. Gitta cheapie from hardware store and grind it yer self to fit the slot tight. Wedgie blades waller-out the slot and make'm difficult to impossible to remove.
Sometimes a broken piece of hacksaw blade inna visegrip can do the trick but its clumbsie. Custom ground screwdriver is more better.
TIP: twirl yer vitron tip pin in the valve seat to "polish" it to help it seal. Should have a ring. ..... ..HTH, Dell
