Order Ford 8N Parts Online
8N timing cover gasket question
Rick8Nrookie
03-01-2008 08:45:04
I removed my timing gear cover off my 1950 8n tractor side mount and now need a gasket or gaskets(?). What I see offered looks like the right one...but this only looks like it is for the "vertical" part of the cover. It looks like I need a "horizontal" gasket also for the bottom of the cover. Are there 2 seperate gaskets for this cover or I'm not seeing the right ones?
Bob
03-02-2008 21:05:36
 Re: 8N timing cover gasket question in reply to allisue, 03-01-2008 08:45:04
If the gasket is still "hanging around", you can re-use it, sealing it up with a bit of silicone gasket sealant, after thotoughly cleaning things up.
Rick8Nrookie
03-02-2008 11:15:11
 Re: 8N timing cover gasket question in reply to Rick8Nrookie, 03-01-2008 08:45:04
So...now that part of the gasket came off when I removed the timing gear cover, the whole oil pan gasket has to be replaced?
Bob
03-01-2008 09:09:27
The oil pan gasket extends forwards, beneath the timing cover.
