Order Ford 8N Parts Online
8N
J. W. Simmons
03-02-2008 14:38:15
I have an 8N I just got, trying to find out what year it is. the serial no. is 437383 which should make it a 1953, but it has an hour meter techometer on it, I thought that did not start until 1954. thanks
J. W. Simmons
03-03-2008 07:12:41
 Re: 8N in reply to J. W. Simmons, 03-02-2008 14:38:15
thanks for all the help. I made a mistake on the serial no. on my 8N. I should have said the serial no. 437383 makes it a 1951. it has a 3J or 31 before the serial no. does anybody know what that is for?
8N'r--WI
03-03-2008 11:06:29
 Re: 8N in reply to J. W. Simmons, 03-03-2008 07:12:41
J.W.----if you don"t mind scratching any paint up, take a wire brush and lightly try to remove any rust and old paint.
In front of the 8 and after the last number, you should see either a "star" or a "diamond".
You can see the "star" on my 1949 pretty easy.
third party image
The star indicated the engine had .040" steel cylinder sleeves.
If you have identified your serial number correctly, you should have "diamonds" in front of the 8 and behind the last number.
The diamond indicates the engine had .090" cast iron cylinder sleeves. Sometime after serial #433...
Just some trivia----probably doesn"t matter much to your N which sleeves are in it---they may have been changed anyhow somewhere along the line.
Tim
Dan
03-03-2008 13:04:44
 Re: 8N in reply to 8N'r--WI, 03-03-2008 11:06:29
third party image
Here is the serial number on my 1948 8N trailer queen. It is a little easier to see.
Dan
Dan
03-03-2008 08:37:48
That is not a "3J" or "3I" - it is a weakly stamped "8N".
Dan
old
03-02-2008 15:32:37
8Ns where made from 1948 to 1952, in 1953 the Jubilee came out and in 1954 the NAA came out. Jubilee and NAA are almost the same tractor other then the emblem up front. If it is in fact a 1953 tractor the engine will have a valve in head engine instead of the flat head that the N series had
dan in co
03-02-2008 14:52:24
Click on this link to see the features and changes to the N tractors.
JohnMD
03-02-2008 14:51:09
The tach started in 1950.
