Order Ford 8N Parts Online
will a backblade stop an 8N from tipping over
Osweld
03-02-2008 17:37:11
read on another site of people killed when tractor flipped over or rolled over, man it makes one think ! Will having a backblade on stop a rear tip over or will the back blade just buckle the arms ?
I guess it could still flip sideways, great something else to worry about
gahorN
03-03-2008 19:24:17
 Re: will a backblade stop an 8N from tipping over in reply to John hunt, 03-02-2008 17:37:11
duey said: (quoted from post at 12:49:35 03/03/08) If you look at the newspapers and the world around you, you'll quickly see that there are FAR more dangerous environments to be in than your tractor seat...
Look at the auto accidents... you're far more likely to get whacked driving to catch a flight than on an aircraft, even.
duey
Using that logic..... that means if you actually manage to get to the airport... you had better NOT BOARD THAT PLANE! :lol:
A back blade will not protect you from a tractor flipping over onto you. The Ford N series has no DOWN hydraulic pressure and the flipping tractor will quite happily continue on over on top of you.
You cannot simply 'use your head' and be fine.... unless you use your head to THINK about each and every operation you perform and do not try new, dumb, untried tasks for which your tractor was never designed.
Tractors are dangerously deadly. Very experienced, life-long farmers get killed by them every week.
duey
03-03-2008 21:20:20
 Re: will a backblade stop an 8N from tipping over in reply to gahorN, 03-03-2008 19:24:17
Think about it, the worst part of the trip is OVER... GET ON THAT PLANE...
We aren't dropping like flies from tractors killing us, now are we?
There just are "acceptable" ways to die, it seems... like traffic, but airplanes and tractor accidents get the headlines...
Your talk about: "Tractors are dangerously deadly" is a great way to get the GOV'T to step in and regulate, you KNOW how you want THAT!!
Like I said, get your head in the game... you'll live a long time. duey
John hunt
03-03-2008 19:17:52
 Re: will a backblade stop an 8N from tipping over in reply to Osweld, 03-02-2008 17:37:11
look on the web site HERE they GOT some cArToOn about SAFETY ..... HERE GREAT TO GIVE OUT TOO
Sean (TX)
03-03-2008 03:22:17
 Re: will a backblade stop an 8N from tipping over in reply to allisue, 03-02-2008 17:37:11
They sell ROPS for the N Series on this site. Think you need a seat belt too!!
GA Dave
03-02-2008 20:51:33
Don't count on anything helping. Use common sense. If it don't feel right don't do it. David.
Bill M. from ILL
03-03-2008 15:43:53
As in most ventures,if it does'nt feel safe it probably is not. Even if one is lucky and gets away with something 99 times the 100th time might kill you, so it's just not worth it. If I have to go up a steep grade with heavy implement on three point I feel safer backing up. Fluid filled tire lowers center of gravity that helps on side slopes. I pull from front bumper if pulling log or similar weight up hill. If tractor flips on side slope or ditch I'm not sure one could bail off over fender and wheel because it would come up so quickly. I'm getting a new tractor with loader so I'll have to get feel of it because a loader with weight will increase center of gravity so much. Best to stay on level ground. It does have ROPS. I'll have to find room in my shed because I can't part with my two old N's! Bill
Bob Harvey
03-03-2008 15:23:38
Use your noodle. SAFETY FIRST !!
duey
03-03-2008 11:49:35
Use your head, keep your foot ready for the clutch, and HAVE A PLAN! If the tractor goes THIS way, I'll go THAT way... take charge of the situation. Keep your HEAD in the game.
Just plan to do your best.
You'll live to a ripe old age.
duey
soundguy
03-03-2008 11:32:02
I agree with the others.. yeah.. some 3pt implements may help stall a backflip.. though something may break or buckle.. just depends.. won't help a side flip..
soundguy
Upper Peninsula,MI.
03-03-2008 09:43:16
I set all the wheels on both my N's as far out as they can be set. Makes me feel safer and is safer. Ron
old
03-03-2008 08:38:35
third party image
Heres what can/will happen if you put a tractor on a slope going side ways. Only thing that saved the guy was the tree and he still went to the hospital for a busted up knee
36 coupe
03-03-2008 02:51:38
85% of tractor rolls are to the side.The top link pins could break.
heybusdriver
03-02-2008 22:54:00
A back blade may help some,it is not fool proof. Caution should always be used in operating any equipment. Stan
8N179555
8N362039
Vancouver Canada, home of the 2010 winter Olympics
every-one welcome.
jon
03-02-2008 18:39:13
Like old said, they could, but it's not highly likely. I'm not gonna say never cause you could turn any moving vehicle over given the right circumstance but a tractor with a blade, scrape, disc, etc has the advantage of a "wheelie bar" effect. Just be smart pulling stuff & don't get on a bad slope sideways, that'll make you pucker a little!
old
03-02-2008 18:30:00
In theory it will but things can/do brake so yep it could still flip over. Now that I have said that I have been saved more then once by having something on the 3 point when the front end comes up but I would not relay on it
