Order Ford 8N Parts Online
cant remove engine hood on 8n ford tractor
od crouse
03-05-2008 13:35:40
something im not un bolting?
need help thanks
Steve(PA)
03-06-2008 04:40:35
 Re: cant remove engine hood on 8n ford tractor in reply to od crouse, 03-05-2008 13:35:40
Just removed mine 52". My kood was cathing on the fresh air vent going to the air cleaner. Removed and off it came.
Dell (WA)
03-05-2008 16:12:25
OD..... ...count yer bolts, 4-onna dash, 2-radiator legs. WATCH OUT fer grill falling out on yer toes after you remove the dogleg bolts. Simple, eh?
TIP: have a pair of sawhorses to set yer removed hood and doglegs onto or yer gonna BEND stuff.
Gitta'helper. Me'n'10-yo son removed mine so could replace the rusted out radiator. It ain't so much heavy as it is AWKWARD stumbling over the front axle..... ...Dell
Dunk
03-05-2008 15:07:53
One thing not mentioned so far is the radiator cap.... :D
LeeMo
03-05-2008 13:56:51
There's the four bolts around the dash and the 2 on the doglegs. If there's a lot of gas in the tank that'll make it real heavy. The gas tank comes with the hood. You'll need to disconnect the fuel line and wiring for headlights if it has those. I usually drain the tank so I can remove and replace the hood by myself.
Good Luck, Lee
wayne2
03-05-2008 13:47:03
1/2 bolts around inst. panel and 2 front bottom.
