Set the clocks ahead 1 hour
Dan in CO
03-08-2008 18:31:17
I just finished setting the clocks ahead & thought one or two of you might not have gotten the word.
OKDAD
03-09-2008 09:20:38
 Re: Set the clocks ahead 1 hour in reply to old, 03-08-2008 18:31:17
Dan...That would be expected if you are running XP and manually adjusted it sometime in the past. Then a recent update from MS fixed the DST date change so it overcorrected last night.
If you are running Win 2K then you need to use TZ Edit to fix it.
Dan in CO
03-09-2008 06:34:51
 Re: Set the clocks ahead 1 hour in reply to mntnvew, 03-08-2008 18:31:17
OKDAD said: (quoted from post at 00:31:14 03/09/08) Computers should be fine if you are running XP w/latest updates or Vista. Win 2K or older systems will have to have been set w/TZ Edit.
Don't know squat about MACs so you Apple lovers are on your own. :)
I don't know how, but my computer re-set itself 2 hours ahead!
GB in MT.
03-09-2008 07:23:58
 Re: Set the clocks ahead 1 hour in reply to Dan in CO, 03-09-2008 06:34:51
Dan in CO said: (quoted from post at 06:34:51 03/09/08)
Dan;
Go to " Adjust Date/Time" then "Time Zone" to check and see if it has reset itself for another time zone, when you had that power outage the other day!!!!! !????? :roll:
Just a thought!!!
Gary :)
OKDAD
03-08-2008 22:31:14
 Re: Set the clocks ahead 1 hour in reply to Mike OH, 03-08-2008 18:31:17
Dunk
03-08-2008 19:53:17
 Re: Set the clocks ahead 1 hour in reply to JohnMD, 03-08-2008 18:31:17
Tom N MS said: (quoted from post at 00:33:33 03/09/08) Isn't it amazing how time conscious we are..Fifteen clocks to set at my house(includes 5 computers). I guess they will be smart enough to set themself..Well, maybe not....
Crazy I tell you!!
But as long as it makes the check signer happy....
I'll try to be "on time"....
Tom N MS
03-08-2008 19:33:33
 Re: Set the clocks ahead 1 hour in reply to Dan in CO, 03-08-2008 18:31:17
Dunk
03-08-2008 18:39:48
 Re: Set the clocks ahead 1 hour in reply to Pincheweddo, 03-08-2008 18:31:17
Dan in CO said: (quoted from post at 23:31:17 03/08/08) I just finished setting the clocks ahead & thought one or two of you might not have gotten the word.
Thanks, Dan.
Just adjusted my wrist watch, per yer instructions.
Computers "should" handle it on there own, we'll see...
