Huffie..... ...I like well composed questions with sufficnent descriptions of what you've done, thank you. Surprizingly enuff, the rotor should NEVER touch the distributor contacts. Them sparkies just jump'em like they do the real gap in the sparkplugs. (iff'n everything is working correctly) Therefore, you should NEVER read continuity from sparkie wire terminal to the rotor. Why? 'cuz its'n OPEN circuit. Ah yes, points and condenser, mysterious things for ignition illiteratii. Heres the deal, sparkies only occur when points OPEN. When closed, points DC current (about 3-amps) creates a BIG magnetic field thru the coil primary winding and coil magnetic core. When the points OPEN, the magnetic field suddenly collapses and creates the HIGH volts needed for the sparkies to jump the gap. The condenser sucks-up excess electrons that would jump-back across the points and BURN them. Why is burned points a bad thing? The "burn" is a resistive corrosion that reduces the AMPS (current) needed to generate the magnetic field to make sparkies sparkle. You write..... ."I was expecting some action on the coil to distributor lead"..... .yep, when the points are OPEN, you should read battery volts. (in yer case, 12-volts) When the points are closed, you should read about 3-volts, iff'n its a 6-volt coil, about 9-volts iff'n its a 12-volt coil. You probably won't seen much action iff'n yer turning over yer engine by the starter, probably close to battery volts. You write..... ."I have power to the coil – 12 volts. Same voltage to the pig tail on the coil. I get seven volts from the coil on the tang to the distributor cap"..... ..WHOOPSIE!!!!..... since yer ignition coil is "auto-transformer" (which is a type of transformer design where the primary and secondary are internally connected together) and since the only way to connect to the coil springy-thingy and the coil tang is out in mid-air, your TANG should read the same volts as yer springy-thingy. Iff'n you reported everything correctly, then yer sparkie problem is..... .are you ready for this??? ..... .BAD IGNITION COIL. The squarecan ignition coil is barely addiquate and doesn't have much a margin for poor contacts and even worse, when used in 12-volt conversions, they tend to OVERHEAT and melt the internal insulative tars. Hope has answered yer questions. And NO, I don't know how to tell whether you have the OEM 6-volt coil or the modern 12-volt conversion replacement coil. It could be molded into the bakelite just like they do to tell you iff'n made in China or Mexico. Duh..... ...Dell
