Order Ford 8N Parts Online
8n tractor problem
SCANLIN
03-09-2008 09:10:21
MY FATHER JUST PURCHASED A 8N TRACTOR WHEN YOU PUT IT IN GEAR IT LOCKS UP THE MOTOR RUNS FINE I HAVE LOOKED AT THE TRANS TO MAKE SURE ITS NOT IN TWO GEARS AT ONCE DOES ANYONE HAVE A SUGGESTION CAN THE PTO CAUSE THIS
Bill(NC)
03-10-2008 04:24:40
 Re: 8n tractor problem in reply to SCANLIN, 03-09-2008 09:10:21
I have an 8N that must get warmed up before you can put it gear and let the clutch out. I think, for some reason, the transmission oil has to get warm.
Also, the governor may cause the tractor to kill the motor when you put it in gear.
Just something to think about.
SCANLIN
03-09-2008 12:25:39
ok heres the deal when i pulled the shifter cover i made sure the trans was not locked in two gears when its in nutural it rolls when you would put it in gear with or with out using the shifter it would lock up i pulled the lift assy out and drained all the fluids and cleaned everything as well as possible i started back together and so far its not locked up i agree it was locked like being in two gears but i could not see it that why i was wondering if there is something else thanks in advance ps. everything was full of water almost like it was sumerged
Dell (WA)
03-09-2008 14:09:16
 Re: 8n tractor problem in reply to SCANLIN, 03-09-2008 12:25:39
Scannie..... ...yeah, that happens when the trannys shifter rubber boot "splits". New tranny shifter boot $3. (cheap) tip: BOIL yer new tranny shifter boot and install HOT. Boiled makes it eazy to stretch. ..... .Dell
Dunk
03-09-2008 11:03:21
 Re: 8n tractor problem in reply to joe in wilkinson, 03-09-2008 09:10:21
SCANLIN said: (quoted from post at 14:45:01 03/09/08) YES I DID ITS NOT IN TWO GEARS AT ONCE I JUST PULLED THE PUMPS OUT AND CLEANED THEM THERE WAS A LOT OF WATER I STARTED GOING BECK TOGETHR AND TESTING IT AFTER EACH PEICE I INSTALLED SO FAR ITS UNLOCKED ANY IDEALS
Here is what I would try.
I would jack both rear wheels off the ground, and with the tractor in neutral, turn one tire, and see what happens, and how it feels, and how the opposite tire turns.
Then try turning both tires at the same time, in the same direction, and see what the results are.
Den N Ms
03-09-2008 10:25:16
SCANLIN,Have you tried to let the clutch out with the engine running and the shifter in neutral?It sounds to me like its shifting into two gears at once,locking it up.
SCANLIN
03-09-2008 10:45:01
 Re: 8n tractor problem in reply to Den N Ms, 03-09-2008 10:25:16
Dell (WA)
03-09-2008 10:59:07
 Re: 8n tractor problem in reply to SCANLIN, 03-09-2008 10:45:01
Scannie..... ...OWEE!!! yer CAPS are hurtin' my eyeballs. Caps are equivalent of YELLING!!! TIA
NO..... ..it is NOT yer PTO
As I understand it, you can "start" the engine with the clutch pedal down, but just can NOT let yer clutch pedal UP without the engine dying.
I know you are ADAMANT in insisting yer tranny is NOT in 2-gears at once. BUT that is the ONLY cause of killing the engine when letting out the clutch pedal. Generally caused by worn tranny shifter plates..... ....Dell
