rope seal and pulley again. pic.
Patrick 2n Mary
03-10-2008 14:01:27
Ok guys I am trying to get my factory front pulley installed all the way on. Dan was nice enough to help me out saying that he measured 1 9/16 pulley and the same for the crank nose. My question now is how far out the nose does the key stick. My pulley is really tight and i can not turn it or pull it in or out. I measure that it still has 1/8 (.1300) to go till it is flush. My problem with all this is if it has only 1/8 to go them am i all the way on or is it started on the key. If it was not lined up with the key at all how far would it be out form the end of the crank? Hope my pic. works. I am new to that part.
Hobo,NC
03-10-2008 14:57:16
 Re: rope seal and pulley again. pic. in reply to Patrick 2n Maryland, 03-10-2008 14:01:27
I think you are on the way,,, give it a good whack, use 2 hammers,, one on the snout and whack it with the other,,, once up its not zackly flush but close to it,,, 'bout a 1/32
Patrick 2n Maryland
03-11-2008 08:48:04
 Re: rope seal and pulley again. pic. in reply to Hobo,NC, 03-10-2008 14:57:16
Thanks it is on now. Wow was it tight!
Patrick 2n Maryland
03-10-2008 15:02:49
Ok. that is what i thought. I used a bearing race driver to hit where the nut seats.
ron,ar
03-10-2008 14:28:12
 here is the picture in reply to Patrick 2n Maryland, 03-10-2008 14:01:27
third party image
I don't have an answer for your question but it looks good!
Patrick 2n Maryland
03-10-2008 14:12:02
retry picture. Link
Jack L
03-10-2008 15:23:15
 Re: rope seal and pulley again. pic. in reply to Patrick 2n Maryland, 03-10-2008 14:12:02
Patrick, when I try to post a photo I have to remove the brackets and IMG from the front and rear of the ur Let it start with>Link
HTH
Jack
