Frame-mounted Swinging Drawbar
Rick WY
03-10-2008 18:43:05
Does anyone know anything about this interesting swinging drawbar setup? Is it an original Dearborn/Ford accessory or aftermarket? No tag or identification was noted. I am quite certain it was manufactured - not a farmerization. I"d be concerned lifting or pulling anything too heavy with it? Seems like a drawbar should pull low and from below the axle. It would work well for a side delivery rake. Thanks for any information.
third party image
soundguy
03-11-2008 07:22:13
 Re: Frame-mounted Swinging Drawbar in reply to Rick WY, 03-10-2008 18:43:05
i agree with ultradog.. you can probably pull lower witht hat frame than a diffy case mounted drawbar. Add somestays and you got it made..
soundguy
Ultradog MN
03-10-2008 20:57:49
third party image
It's an interesting piece for sure.
Not a lot different than the type they sell on Ebay except for the swinging drawbar.
It would pull from as low as your lower lift arms would drop which is lower than a standard drawbar.
Safe enough if you don't have it raised up high.
Dan in CO
03-10-2008 20:03:14
Rick:
Can’t help out with the swinging draw bar, but I am curious if you got to Dean’s place over the weekend? I got your voice message, but too late in the PM to return.
