Ignition wiring diagram
Alex Cuevas
03-11-2008 04:43:49
Does anyone have a simple wiring diagram for a positive ground original 6 volt 1942 Ford 9N tractor. The diagram in my shop manual sucks. This is my final step in the restoration and has held me up for 2 months.
Bob Harvey
03-11-2008 16:38:58
 Re: Ignition wiring diagram in reply to Alex Cuevas, 03-11-2008 04:43:49
Yoiks !! Easy way is to check the Archives..... ...LOTS of diagrams and info.
JMOR
03-11-2008 10:40:17
 Re: Ignition wiring diagram in reply to Dan, 03-11-2008 04:43:49
Alex Cuevas said: (quoted from post at 13:09:17 03/11/08) Still have a problem, not much going to the coil. When I check for power with a test lamp I get a strong bright light at the terminal block and on the left side of the resistor (terminal block) I have no power on the right side of the resistor. (left and right facing the front of the tractor) Could I have the wires to the cutout relay hooked up backwards. Or what else could be wrong?
Thanks
Alex
One side (likely where you get strong bright light) is power from the ignition switch. The other side feeds the coil. If the points are closed, much of the battery voltage is dropped across the resistor & might not be enough to light your light..... ...but, if you turn the engine over, the points opening & closing should make your light blink on & off.
JMOR
03-11-2008 06:03:37
Are you looking for more of a pictorial of where the wires run or a schematic?
GB in MT.
03-11-2008 06:34:19
 Re: Ignition wiring diagram in reply to JMOR, 03-11-2008 06:03:37
JMOR said: (quoted from post at 06:03:37 03/11/08) Are you looking for more of a pictorial of where the wires run or a schematic?
LOL
Or..... a movie maybe!!!!????
Spose???
Alex Cuevas
03-11-2008 06:29:14
Both if you have it.I just received one that I think will work, but if you have another I can use it.
Thanks
Alex
soundguy
03-11-2008 07:02:19
 Re: Ignition wiring diagram in reply to Alex Cuevas, 03-11-2008 06:29:14
Did you check your manual? Good pics in there..
these tractors have just about the most basic electrical system you can get... a starter circuit, charge circit, ignition circuit, and perhaps a lamp circuit.
soundguy
Alex Cuevas
03-11-2008 10:13:23
 Re: Ignition wiring diagram in reply to soundguy, 03-11-2008 07:02:19
Yes, the manual sucks . That is the only weakness in the manual. Would help if it was in color and not hidden in the harness.
soundguy
03-11-2008 11:49:59
 Re: Ignition wiring diagram in reply to Alex Cuevas, 03-11-2008 10:13:23
Still, it gives you a basic idea of what hooks to what.. not too many feet of wire on these old girls.
soundguy
GB in MT.
03-11-2008 05:21:05
Alex;
Try this one. Should work for ya. Except, Do not use the lights wiring. It's not good to run the lights through the ignition switch.
third party image
HTH
Gary :)
Alex Cuevas
03-11-2008 06:27:33
 Re: Ignition wiring diagram in reply to GB in MT., 03-11-2008 05:21:05
Thanks, that will work.
Alex
Alex Cuevas
03-11-2008 10:09:17
 Re: Ignition wiring diagram in reply to Alex Cuevas, 03-11-2008 06:27:33
Thanks Alex
