Need NAPA Part Numbers
Sean (TX)
03-11-2008 12:42:02
For the head gasket(non-Metalic) and the exhuast/intake manifold gaskets on a 46 2N...
TIA
Sean
Dunk
03-12-2008 06:47:10
 Re: NAPA Lookup in reply to Kevin in OK, 03-11-2008 12:42:02
Jim SC said: (quoted from post at 10:33:39 03/12/08) Dunk, each time I click on "agriculture...", it tells me that I have timed out and it goes blank.
Any advise?
Jim, it must be something specific to your computer or browser.
I just checked it with my Windows 2003 Server Enterprise machine with IE 7, and with my Ubuntu Linux machine with FireFox web browser, both seem to work just fine.
Sean (TX)
03-11-2008 16:28:53
 Re: NAPA Lookup in reply to John (TR), 03-11-2008 12:42:02
Thanks Dunk third party image Didnt know you could look up parts online at napa for tractors...Is that new? see that kit has all the gaskets I need for now...
Dunk
03-11-2008 16:03:42
 Re: NAPA Lookup in reply to Sean (TX), 03-11-2008 12:42:02
From Link
Look in left column for PartsPRO SE CATALOG and click on that,
then
Tractors/Agricultural
Then pick year, and make, and so forth.
I don't know why the urls don't always work....
Dunk
03-11-2008 16:00:39
 NAPA Lookup in reply to jimNCal, 03-11-2008 12:42:02
Sean (TX) said: (quoted from post at 16:42:02 03/11/08) For the head gasket(non-Metalic) and the exhuast/intake manifold gaskets on a 46 2N...
TIA
Sean
NAPA Lookup
Parts Pro SE
Link
Then in left column Tractors/Agricultural
Head Part: FPG 7277B
Features & Benefits
Enhanced Surface Conformability.; Irregular Bore Shape.; Retorque Style Head Gasket.
Attributes
Cylinder Head Gasket Combustion Chamber Opening : 3.273"
Cylinder Head Gasket Material : Composite Facing w/Steel Core.
Warranty
Warranty information is unavailable.
Material Safety Data Sheet (MSDS)
There is no MSDS for this item
Application Information: 1946 Ford Tractor 2N
Engines : 2.0 L 119 CID L4 Ford
Per Car Qty: 1
If that doesn't get you started looking them up, or if you need more help... YELL.. LOL
Jim SC
03-12-2008 06:33:39
 Re: NAPA Lookup in reply to Dunk, 03-11-2008 16:00:39
Any advise?
Sean (TX)
03-11-2008 15:25:13
 Re: Need NAPA Part Numbers in reply to heybusdriver, 03-11-2008 12:42:02
Yes I did :) Pulled the starter pried on it and it turned right over. Just cleaned the head.
Den N Ms
03-11-2008 15:10:29
 Re: Need NAPA Part Numbers in reply to Sean (TX), 03-11-2008 12:42:02
Sean,Did you get Fred to spin over?I hope so.
