Hey Dunk
Sean (TX)
03-11-2008 13:38:30
Dunk said: (quoted from post at 20:24:06 03/10/08) Sean...
I think I would clean that up, put it back together and see how it runs, after running under a load for a few hours.
A for the broken plugs...
I would punch them out in the centers, and blow the preheater on a cutting torch thru them till they turned a really good red, nearly white and let them cool, they should then come right out.
Any shop with a torch should be able to help you there for nearly nothing if you still haven't gotten you a torch.
I am totally amazed that you seem to have removed the manifold studs without any good heat.
That is a good sign IMO that this engine has had work in it's recent past.
JMO, worth what you paid for it.. LOL.
Torch worked like a champ!! third party image Got them red hot. Let them cool and taped them out with a hammer and cold chisel. Think ill put it back together and test the compression.
