PTO Reducer--Curious mind wants to know
8N'r--WI
03-12-2008 10:43:27
Has anyone seen one of these that will fit an 8N?
third party image
third party image
I have not ever seen/nor heard of one for an 8N.
Tim
Dunk
03-14-2008 15:34:55
 Re: PTO Reducer--Curious mind wants to know in reply to Mark Pearce, 03-12-2008 10:43:27
JMOR said: (quoted from post at 18:57:55 03/14/08)
Jim SC said: (quoted from post at 08:15:46 03/13/08) This sounds like it would be getting close to being capable of running a roto-tiller. Throttle back with a huge step-up (almost double) in PTO speed.
Looks like input at bottom, output at top. If that is the case, why step up?
Correct me if I am wrong here.... (and I may very well be)
The bottom looks like the input.
The bottom is smaller and appears to have 14 teeth.
The top is larger and appears to have 17 teeth.
My feeble brain tells me that is stepping down (slowing down).
Slowing down the amount of 0.823529412 ratio or 14/17
Now if one used the 540 speed for the 14, one would end up with a 444.7059 speed.
I may be off me rocker though.....
JMOR
03-14-2008 14:57:55
 Re: PTO Reducer--Curious mind wants to know in reply to dan in co, 03-12-2008 10:43:27
KCM
03-12-2008 22:19:23
 Re: PTO Reducer--Curious mind wants to know in reply to 8N'r--WI, 03-12-2008 10:43:27
I have seen two other versions of an adapter like that. One was either on this site or another Ford N Tractor site. The other was at a tractor show. The one on the tractor site was determined to be for some implement, but can't remember what. Pretty sure it wasn't a Ford brand implement though. With so much aftermarket equipment available back then, guess it could be for any number of things.
lonestarjeff
03-12-2008 19:25:34
Tim....the Ferguson side-delivery rake had a similar chain-driven pto attachment. I've never seen or heard of a Dearborn version(doesn't mean there's not one), but the one in your pic doesn't look like the Fergy to me.
Jeff
BillM (OH)
03-12-2008 12:15:23
Hub City makes both reducers and increasers.
http://catalogs.hubcityinc.com/farmrev/model390.html
Jim SC
03-13-2008 05:15:46
 Re: PTO Reducer--Curious mind wants to know in reply to BillM (OH), 03-12-2008 12:15:23
TheOldHokie
03-13-2008 07:18:03
 Re: PTO Reducer--Curious mind wants to know in reply to Jim SC, 03-13-2008 05:15:46
Jim SC said: (quoted from post at 05:15:46 03/13/08) This sounds like it would be getting close to being capable of running a roto-tiller. Throttle back with a huge step-up (almost double) in PTO speed.
I don't think the tiller driveline would like that stepped up PTO speed much. An even then the ground speed is too fast. Your best bet is still a Howard or equiv.
TOH
