GB in MT.
03-14-2008 08:13:59
Re: 44 2N front axle pin......revisited in reply to Joe in MI, 03-14-2008 07:19:09
Joe in MI said: (quoted from post at 07:19:09 03/14/08) I'm learning a lot from this too. I have the same project coming this spring. I really hope my front axle isn't wallowed out, but I have a bad, bad feeling about it after comparing pictures. Keep the "play by play" going - I'll use it again in a few months.
I have the same spacers on mine. What exacly are the paper thin washers that don't even come close to filling the space supposed to accomplish, exactly?  |
Joe;
Far be it for me to tell you what to do, but...Let me say this.....Do NOT wait too long to do the axle pin job, because if you do, you might just be in the same situation that I am in, OR worse, ya could hurt yer self or your "N". (worst scenario).
As for the spacers you ask about, I'll quote you what I was told!!
Quote: "you want the axle to be able to float a bit" Un-quote.
Yours looks to be done right as to the placements of the spacers, but....Looks to me like you are gonna need more big thin spacers in the back. This, I learned from someone that knows!! I would say for you to keep installing the thin spacers on the back of the pin until you have about the same thickness of one spacer between the spacers and the axle center. That will let the axle play be just enough not to bind up on the axle pin. Or so I have been told.
Also, I don't know what Year of "N" you have, but make sure to reseach the exact pin you need for your tractor, before you buy. 9N's take one kind and length, early 2N's take another. Late 2N's and 8N's take yet another length. Just keep this in mind.
I will not be posting anthing more on this subject, I don't think, until I get to the almost finished project.!!!
Like I said, do NOT wait too long..... it can only get worse!!!!!
HTH
Gary
