early 1944 2N..axle pin pic needed
GB in MT.
03-15-2008 07:40:07
I need a good clear pic. posted, of the axle pin assembled on an early 44 2N, to be able to see exactly where the spacer is and the thin washers are installed.
Pic needed, is of a 2N, with ser# prior to Ser#167,488.
I'm getting so many different statements as to where/how this is set up, I fig. this might be the way to get the info. I need.
The FO4 does NOT show ANY spacers and washers, and my 2N axle pin was so cobbled up, I don't know where anything goes!!!! :shock:
TIA Please help the retard!!!! :?
Gary :roll:
GB in MT.
03-15-2008 07:55:24
 Re: early 1944 2N..axle pin pic needed in reply to GB in MT., 03-15-2008 07:40:07
This is a pic. of my pin setup before dismantle, due to broken pin.
Any help/pic. would be greatfully appreciated.
Thanks
third party image
Gary :)
don b
03-15-2008 07:54:20
Gary..... .no spacers on a 2n. don b
GB in MT.
03-15-2008 08:01:35
 Re: early 1944 2N..axle pin pic needed in reply to don b, 03-15-2008 07:54:20
Don;
Man, am I glad to hear from you!!!!!
So..... NO spacers at all and NO washers ..... .RIGHT?????
Just the items I ordered from you. Pin, Bushing, and bolt &washer kit.
All to be used, and nothing else!!!!????
Gary :D
don b
03-16-2008 09:44:25
 Re: early 1944 2N..axle pin pic needed in reply to GB in MT., 03-15-2008 08:01:35
Gary....if your front end is still 2n...you don't need spacers or washers.If you have original front end parts,the parts book calls for the "E" pin for your serial number,about 1/4" longer than "D" pin.Have fun. don b
GB in MT.
03-16-2008 09:59:18
 Re: early 1944 2N..axle pin pic needed in reply to don b, 03-16-2008 09:44:25
Don;
Thanks a heap. The pin I did order was the pin from your site, listed as, for the 43-44 2N only, and the reason was that the pin used was about 4 1/4", and it was in fact needing 4 3/4".
So.....with the info. you have given me, and my messuring, I think everything will be correct. I'll know for sure, when the UPS guy gets here Tues.
Thanks again for the posts and the help!!!!!
Gary :D
